Old 12-17-2019, 02:23 PM   #1
Merriam , KS
Snap Pads
Anyone use SnapPads on their stabilizer feet? Considering this, assuming they have a size that will fit, or something I can modify.
Asking for a 2017 Classic 30.
https://rvsnappad.com/products/eq-co...xoCEn8QAvD_BwE
DougC27 is offline   Reply With Quote
Old 12-17-2019, 02:29 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I have not used them so take this with a grain of salt.
I first used the plastic LEGO blocks.
Then I cut up a rubber door mat in to 4 squares that could sit under the feet (not a glove like fit - they just sat on top).
Then someone in the forums made mention that in the unlikely event the trailer gets hit by lightning, itís best to have the metal feet in direct contact with the ground.
It made sense to me so I donít use anything for that purpose now
Having said that - if youíre looking for something like the product you linked - a $15 rubber welcome mat cut to 4 square may serve the purpose at a steep discount over the product referenced. It will not be a custom fit but once the stabilizer pad is on the rubber square - the square isnít moving anywhere.
Last - this product references a fit to an Equalizer Stabilizer Pad - not sure thatís what comes on an Airstream - I think theyíre BAL stabilizers? I could be wrong....
Hope this is even marginally helpful
Old 12-17-2019, 03:40 PM   #3
Merriam , KS
Thanks for the responses!
MAC:
I found this on the lightening issue...http://noshockzone.org/lightning-safety/
It states that the Airstream forms a Faraday Cage around us and lightening is powerful enough to find the ground even if it is insulated from the ground. I wonder if "making the connection" with jack stand or stabilizers defeat the Faraday Cage and rather than the electricity "bending around the Airstream, it becomes part of the circuit, and thereby, more dangerous.
You make a good point about fashioning my own pads from an economic standpoint. And I intend to attach the pad to the stabilizer foot to virtually eliminate the need to place Legos or anything manually.
Our Airstream has the Lippert motorized stabilizer with a little square foot pad that's about 5".
https://www.etrailer.com/Camper-Jack...hoCyKMQAvD_BwE
Old 12-17-2019, 04:46 PM   #4
2020 Classic 33
Box Elder , South Dakota
Doug, I've seen them on motorhomes. Pretty heavy, way overkill for the weights from the stabilizing jacks on the AS. I use the plastic stacking lego blocks. Most often I put them under the feet every time I park, more to keep the feet clean and also to spare the grass/asphalt/gravel. I do use 12x12 pads from Bigfoot Outriggers for the front tongue. 3 - 2" thick pads. I've used the legos and wood in the past but after using the BigFoots for my motorhome they are indestructible, solid, don't absorb water like wood, and don't bend an warp like legos.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 12-18-2019, 06:28 AM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Stabilizer Pads Are Unnecessary
I believe the point made in the article is that tires (or pads under the stabilizers and jack) will not impede the flow of a lightning strike to earth, however the shell of the Airstream will help to flow electricity around the shell, protecting the inside occupants.
I find that putting pads under the stabilizer feet is totally unnecessary (but may be important to those fastidious people who feel the need to keep the bottoms of the stabilizers untouched by dirt.) I just hose them off if they get too dirty. This also saves the space, weight and dirt of storing those 'lego' or rubber pads.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 12-18-2019, 06:49 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I don't usually put anything under the stabilizer pads on Lucy. The only times that I do is when the ground is mushy or when the terrain is such that some of the stabilizers will not reach the ground solidly when fully extended.
In these cases, I use "legos" under Lucy's stabilizer feet.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 12-18-2019, 07:58 AM   #7
richw46's Avatar
Lexington , Kentucky
When lightning strikes a vehicle it usually blows out the tires. If it has traveled several miles through the air to your vehicle it's very unlikely that 3/4" of rubber is going to stop it from reaching the ground. A single bolt of lightning can be up to a billion volts.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
richw46 is offline   Reply With Quote
Old 12-26-2019, 03:43 PM   #8
2018 30' Classic
Williamsburg , VA
I saw them at the Hershey RV show and liked that they didn't need removed each time. I was concerned about the size so I took them to the Airstream vendor at the show and none fit. They are supposed to email me when they have a size that fits. Maybe they will.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 01-02-2020, 09:20 AM   #9
Journeyman
2016 25' International
Deerfield , Massachusetts
Hate to be "that guy" on the forum, but I believe that a bolt of lightning is approximately 1.21 jigawatts.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 01-02-2020, 11:36 AM   #10
richw46's Avatar
Giga watts?
Oooooh, the flux capacitor capacity. It's what makes time travel possible. Great movie series.
-Rich
Rich & Yvonne
snap ring removal gary Windows & Screens 12 07-04-2013 12:42 PM
Snap stud head came off! TennisMan Awnings 8 07-11-2009 10:39 AM
Lifted AS - SNAP CRACKLE POP? netlace General Repair Forum 14 07-02-2009 02:01 PM
Source for ZipDee Snap Pins? Bob Thompson Awnings 7 03-19-2007 05:04 PM
Lost the snap up lever to my Equal-i-zer hitch 63air Hitches, Couplers & Balls 9 06-08-2006 08:41 AM
