Old 06-30-2022, 10:09 AM   #1
2019 30' Classic
San Jose , California
Showermiser experience anyone?
Hello! Has anyone had any experience with the Showermiser? (https://www.showermiser.com). Seems like an obvious and effective water conservation capability, but I am not sure the complexity of reaching the fill, vent, and pressure lines.
Ron
2019 30' Classic RBQ
ronalddodge is offline   Reply With Quote
Old 06-30-2022, 12:01 PM   #2
dznf0g's Avatar
Oswego , Illinois
I have had mine installed for a couple years now. Definitely worth it if you utilize sites with no water hookups.
Sent from my SM-G950U using Airstream Forums mobile app
-Rich-
Old 07-01-2022, 02:20 PM   #3
Freedom
KCurtis's Avatar
2020 25' Flying Cloud
Dallas , TX
If you have a wife that washes her hair in your Airstream then she probably will not like it. Of course this depends on how long and thick her hair is. Mine didn’t care for it at all because of this. Plus, we rarely boondock and that was why I bought it in the first place.
2020 25RB We named her Freedom
2023 30 Foot Classic on order
2022 Ram 3500 Dually
WBCCI: 26506
KCurtis is offline   Reply With Quote
Old 07-02-2022, 01:12 AM   #4
2019 30' Classic
Hi - thank you for the feedback based on your experience. However, I’m not sure I understand it. The concept is that the showermiser recycles the fresh (cold) water as the water heater brings the temp up. How would this be an issue for someone washing their hair? I would think that this would be a huge benefit…
I am likely missing something and would love to understand better.
Old 07-02-2022, 05:55 AM   #5
2014 25' Flying Cloud
New Ashford , Massachusetts
Not sure what the real water savings is? 100 feet of 1/2 pex tubing has a volume of .92 of a gallon. How much water can there be between the water heater and the shower head? Let the water heater get to temp, turn the shower head to full hot, flush out the 10 feet of line (less than 1/10th of a gallon) then adjust to temp. Not really a savings. Shutting the shower head off between lathering up and rising saves more than that. JMO
Joe D
Dexterpix is offline   Reply With Quote
Old 07-02-2022, 06:04 AM   #6
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Joe D
You can still turn off the water while washing. The showermiser allows you to recirculate the water back to the fresh tank as it reaches temperature. You open the valve once it’s up to temp. My OEM on demand heater takes roughly 40 seconds or 1/2-3/4 gallons to kick out warm water.
- Stewart
s1000pre is offline   Reply With Quote
Old 07-02-2022, 08:47 AM   #7
Freedom
KCurtis's Avatar
Dallas , TX
You are correct… my mistake. I was thinking of the shower head. I do wish Airstream would install this product on their trailers in the factory though. It makes perfect sense.
WBCCI: 26506
Old 07-02-2022, 11:01 PM   #8
2019 30' Classic
I get it… the gain may be small. I have a 2019 classic and on a cold day, i watch 1 to 2 gallons of fresh water fill up the gray tank while warm water makes it’s way to the shower head. I know how to conserve water once the shower is running at temp (30 years in the army…many times without warm water…).
I would love to hear how others reduce the waste. I turn on “max” hot water via the Alder panel for about 15 minutes before starting the shower. Any other tips?
Ron
Old 07-03-2022, 06:46 PM   #9
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
We have a 18 classic and just catch the water and use it elsewhere like cooking or watering plants. It’s mostly important when boondocking to preserve tanks and keep you out longer.
If you’re hooked up we mostly just let it go down the drain and just dump grey often while on sewer.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 07-03-2022, 07:14 PM   #10
1988 32' Excella
Robbinsville , New Jersey
Joe D
Your trailer came with a water heater with a tank. This is to save water with the new tankless water heaters that have a delay from the time water starts flowing before the water heater even starts heating water on RVs.
Old 07-04-2022, 01:47 PM   #11
That makes sense! Could not understand the savings in my set up. Does seem that Airstream has done everything it can to make boondocking more complicated with the "upgrades" on the new units. My water heater is an additional 6 gallons of water to start the trip with when we fill up.
Thanks for the info
Joe D
Aquaview Showermiser & Sinkmiser s1000pre Plumbing - Systems & Fixtures 5 06-23-2022 08:32 AM
showermiser JMann General Repair Forum 2 05-30-2022 09:52 AM
Showermiser or similar for tankless water heater s1000pre Plumbing - Systems & Fixtures 1 01-06-2022 06:32 AM
Sovereign 1992: Want to cut a window in the roof. Has anyone experience? Hans Roof 20 01-18-2003 05:23 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
