Old 04-05-2019, 10:16 AM   #1
2019 33' Classic
Scottsdale , Arizona
Shower Antiscald Adjustment
Iím trying to adjust the anti-scald valve in the shower. I pulled the handle off, and there is a ring I can see that limits the travel on the handle, however I canít seem to be able to adjust the ring. all the documentation that I can find for shower handles on Kohlerís website shows a different set up with a set screw. There is no setscrew on this model. Is anyone familiar with this particular model, see picture included.
trepine is offline   Reply With Quote
Old 04-05-2019, 10:21 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
You should be able to pull out on the brown ring and turn it clockwise and pressit back in place over the splines.
Old 04-05-2019, 10:25 AM   #3
2019 33' Classic
I can pull it out about 3 mm, but it won’t turn. It doesn’t pullout easily more than this, and i’m hesitant to force it too much. There are two holes on either side that look like they have some clip in them. but i’m not sure if or how to do anything with that.
Old 04-05-2019, 10:27 AM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
It should pop off. Held in place with a spring retention clip
Old 04-05-2019, 10:33 AM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here is a link to the instructions. Note step 8
https://s2.img-b.com/build.com/media...tion-guide.pdf
Old 04-06-2019, 05:35 AM   #6
2019 33' Classic
Thanks for the link. Not sure why i couldnít find that.
The issue i was having is there is a piece that has to be removed to remove the ring. Looking at it, it seemed that the bronze piece was solid. But if you remove the screw it comes upset.
Old 04-08-2019, 04:42 PM   #7
Rosieriviter's Avatar
2013 25' FB Flying Cloud
2018 30' Classic
Campbellsport , Wisconsin
I have same problem this Spring. Hot shower water for 30 seconds. Last year never a problem bath as long as we wished..Rosieriviter is 2018 Classic twin. Anyway I cannot get the shower handle off the Kohler unit. No set screw .
Donít want to bust anything Iím pulling cautiously hard..what am I missing...?
Rosieriviter is offline   Reply With Quote
Old 04-09-2019, 03:10 AM   #8
2019 33' Classic
It took me a few minutes to figure it out. Notice the handle has a part that moves in the front and a fixed part in the back. Hold the front of the handle and then twist the back part counter clockwise. This unscrews the handle and it will pull off.
Then after the handle is off unscrew the screw in the center and pull the silver and copper piece off.
Then pry the collar off, turn the shower full hot (or as hot as desired), and then push the collar back on up to the stop.
Then put it all back together.
Old 04-09-2019, 04:55 AM   #9
2018 30' Classic
Thanks for your input. Iíll try it this morning
Shower door adjustment Larry C Sinks, Showers & Toilets 12 05-12-2019 12:41 PM
Shower door adjustment dmnichols General Repair Forum 10 01-05-2015 05:20 PM
Proper Adjustment for Shower Door John Geisen Sinks, Showers & Toilets 3 08-22-2010 10:36 AM
Shower Door Adjustment rp709 Sinks, Showers & Toilets 1 10-13-2009 02:37 PM
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 05:50 AM
