RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-27-2020, 08:18 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Shore power issue
Our Classic has been sitting at a RV Resort close to Myrtle Beach since Labor Day. We go down every other weekend. We just arrived here for a long weekend and found a battery alarm going when we entered the trailer. It says battery is critically low and that the shore power is not connected. Shore power is connected and our EMS surge protector says everything is normal. We know we have shore power because I am able to run both AC's at the same time. Why would it say shore power is not connected when we know it is?
jlandreth is offline   Reply With Quote
Old 10-27-2020, 08:27 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Is the breaker to the charger tripped?
GMFL is online now   Reply With Quote
Old 10-27-2020, 08:29 PM   #3
2018 25' International
Slidell , Louisiana
Sounds like the converter is off. There is a breaker for it. Check that first. Confirm the battery voltage is low and if so connect the vehicle to begin charging or add an external charger. Then we can come back to look closer at the converter. report back what you find.
Brian
Old 10-27-2020, 08:43 PM   #4
2019 30' Classic
Thanks guys, one leg of the first breaker was tripped. Couldn't tell it by sight but when I touched it it tripped. I reset it and now everything seems to be working fine. There is something running behind the breaker box that I assume is the charger. Thanks again.
Old 10-27-2020, 08:46 PM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
That would be correct. The charger is mounted to the floor behind the panel.
Old 10-27-2020, 09:47 PM   #6
2019 30' Classic
I'm not sure how long the batteries have been low. I hope I haven't damaged the AGM batteries. Do the solar panels charge the batteries through the same charger?
Old 10-27-2020, 09:52 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
No the panels charge through a different charger. I believe your year model uses a Victron and it is located in the cubby under the closet down bottom where the CZONE control board is located. It should be mounted on the wall closest to the rear of the trailer.
Old 10-27-2020, 10:04 PM   #8
2019 30' Classic
So the batteries were getting a charge during the day from the solar panels even though the onboard charger had tripped. Hopefully then the batteries aren't hurt.
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 03:57 PM
My first warranty issue after three weeks--faulty shore power receptacle. Zymurbrian Electrical - Systems, Generators, Batteries & Solar 10 11-13-2012 10:09 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 07:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 12:52 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
