05-30-2018, 03:37 PM
2018 30' Classic
Bothell
Reset Firefly
We had to have our battery disconnected for some work.
Now the firefly can not figure out how much fresh water we have, how full the black and gray tanks are and the temperature in the front.
Any suggestions on how to reset?
Chuck
05-31-2018, 05:02 AM
2018 30' Classic
Cumberland
, Maryland
Make sure all wires in the battery box where reconnected first. Then I would try hitting the battery disconnect switch (off then on). It's like a re-boot on your computer. Make sure your not plugged in to shore power while doing this. Good Luck!
05-31-2018, 08:47 AM
2018 30' Classic
Bothell
Airhead,
Thanks. When you say battery box, are you referring to the gray box under the middle of the couch?
Chuck
05-31-2018, 09:22 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Originally Posted by charlesk
Airhead,
Chuck
Battery box is the box outside in front where the batteries are located. Make sure they are hooked up and hooked up correctly. I took a cell phone picture, sent it to my laptop and my wife's phone so we are sure we have them hooked up correctly.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
05-31-2018, 09:30 AM
2018 30' Classic
Bothell
Our batteries are now lithium inside the trailer. Everything is working fine except the tank sensors on the firefly (which do show up on the panel under the sink correctly) and the front only temperature probe.
Hmmm.
05-31-2018, 11:44 AM
Upper St Clair
, Pennsylvania
Hmmm.
What Lithums did you add and what modifications did you have to do with the hookup or solar?
Bud
05-31-2018, 09:06 PM
2018 30' Classic
Bothell
Hi Bud,
Lew (AM Solar installer) installed Victron Lithium’s ( 2 x 200 amp hr), Victron solar Controller kit, Magnum MSH3012 Inverter and 600 Watts solar on roof.
Chuck
06-01-2018, 04:33 AM
Upper St Clair
, Pennsylvania
Thank you Chuck.
Might contact Lew when he is in Naples.
Bud
06-01-2018, 05:00 AM
2018 30' Classic
Cumberland
, Maryland
Sorry Chuck, I am clueless in regards to your set up. Sounds like Paiceman has a handle on it though. Good Luck!
06-01-2018, 06:34 AM
2017 30' Classic
Cave Creek
Chuck
I suggest go right to Firefly technical support for troubleshooting. 574-825-4600. Have your VIN and the two firmware version numbers- these are found in the menu on your Firefly panel.
Pete B55
2017 Classic
2017 F-250
06-02-2018, 09:40 AM
2018 30' Classic
Bothell
Problem solved (mostly).
Tried to call Firefly but they were already closed. Fortunately, I found another thread where someone else spoke to a tech.
The tech recommended disconnecting from shore power, then disconnect the battery. Guessing the red switch by the door. Since I have lithium batteries, I also had to turn off the master battery switch.
Wait two minutes then turn the battery back on. This will reset the firefly.
This took care of most of my issues. I think the other is a disconnected wire.
Hope this helps.
Chuck
