10-02-2020, 02:44 PM
Lexington
, Kentucky
Quick question Living Area Fantastic Fan shade?
We have a new 2020 33’ Classic RBT. The bedroom fan has a nice shade with it. The Galley/Living area fan does not. Obviously being able to block out all light in sleep in situations (of which there are many  ) is important. Did I get shorted or just bad design point??? Thanks!
10-02-2020, 02:54 PM
2018 30' Classic
Thousand Oaks
I’ve got a 30 classic. Sounds like our design got shorted one fantastic fan and two shades 🤪
We only have one fantastic fan in the living area with no shade. I have seen people add a shade.
Sorry, just commenting, not sure if the 33 calls for two shades or not.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
10-02-2020, 04:11 PM
2020 33' Classic
St Tammany
, Louisiana
Mine has one shade in the Bedroom-
Hope this helps.
Chip
10-02-2020, 04:21 PM
2019 30' Classic
New Milford
, Pennsylvania
We have a 2019 30ft Classic. It has the lowest cost whinny three speed none reversible fan they could find with no cover.It is not long for this world.
10-02-2020, 04:28 PM
2017 25' Flying Cloud
Fort Worth
We have two fantastic fans and neither had a shade. Installed one of these at each location.
https://www.campingworld.com/rv-vent...E&gclsrc=aw.ds
Matches the shade at the skylight with same performance. Not a complete blackout. But does make a big difference.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB - “Fly Fish Inn”
2010 F250 Lariat
10-03-2020, 10:24 AM
2012 23' FB International
Charlotte
, NC
We bought two shades (similar to the one above) but they also have lights. We love them. We replaced the fantastic fans with Maxx Air fans and love them, too!!
2012 23FB International Serenity #Dorytheairstream
2019 GMC Sierra 1500 Crewcab 4WD Denali
"Denali & Dory"
10-03-2020, 10:26 AM
2017 27' Tommy Bahama
Narragansett
, Rhode Island
Fantastic Fan Sun / Heat shade
Just got a Camco ceiling vent shade. It has silvery sun reflective material on one side and the rest is a kind of white lambs wool material. Sure It is synthetic. The shade is filled with a foam square. It is 14x14 inches and squeezes in the space easily. Because it is squishy, it goes over the handle and other protruding items no problem. It stays in well so far when we travel, no light gets through, and it keeps out heat/ cold very well. $15 or so at many locations. Here is a link to Walmart:
https://www.walmart.com/ip/Camco-45192-Sunshield-RV-Vent-Insulator-with-Reflective-Side-14-x-14/29764495?wmlspartner=wlpa&&adid=222222222280214756 83&wl0=&wl1=g&wl2=m&wl3=40839451232&wl4=pla-78652896992&wl5=9002226&wl6=&wl7=&wl8=&wl9=pla&wl1 0=8175035&wl11=online&wl12=29764495&veh=sem&gclid= EAIaIQobChMIrZLxutuY7AIVQeG1Ch2aPAiOEAQYBSABEgKPqP D_BwE
This works way better than any of the make-shift solutions I have tried in the past.
10-03-2020, 10:31 AM
2017 22' Sport
NCR
, Ontario
I made a cheap one that snug fits in. To further secure it, I just pull the shade to keep it from wiggling out while driving
Easy build, 1/8 plywood, solid pink foam and spray on contact cement, lay alum foil on top.
In hit sunny places it does agreat job to keep the temp diwn
10-03-2020, 11:35 AM
2017 30' Flying Cloud
Nashville
, Tennessee
We use a Camco ceiling vent shade. It is soft enough to fit over the handle, created a permanent dent. Doesn't fall out when towing. Easy, inexpensive quick fix.
10-03-2020, 03:51 PM
SHE SHED
2019 30' Classic
Brooklyn
, New York
We cut a pice of styrofoam less than 3/8" smaller than the opening, used a spray adhesive to put a nice matching material on the foam, put an inexpesive matching draw handle in the center with wide washers on the back, and used Frost King self adhesive 1/4" window foam sealer around the perimeter. Pop it in.
10-06-2020, 12:55 PM
2018 33' Classic
Fresno
I had the same issue in my 33, cock-a-doodle doo when the sun came up before I was ready.
Solution; a piece of acoustic black foam cut to just over the inside dimensions
of the sky lite opening. I think it was 13 1/2" x 13 1/2" but you should measure your sky lite opening to be certain. If you cut it about 1/2" over inside dimensions the foam will compress with enough push back to keep it in place. A 48"x24"x1" piece of bulk foam costs $20 from amazon (link below).
If you choose this solution, lay out the cut lines with masking tape and cut along the edge of the tape with a sharp butcher knife dragging the knife several times along the cut path until you are all of the way through. Be sure to double check your measurements and cut along the correct side of the tape. If done correctly it squeezes in and stays put without any messy adhesives or unsightly fasteners. Put it in or take it out hassle free. If black is not the color you want you can always paint it I suppose, maybe silver.
With the leftover foam I cut a 12"x7" piece and use it when I sleep to keep my boney knees apart.
Let me know how it works for you.
10-07-2020, 05:52 AM
2012 25' FB International
Trent Woods
, North Carolina
Holy cow, all these people who sleep after the sun comes up! Sunrise, especially while camping, is one of the great joys of life!( Sunrise was better sailing, though)
Larry
10-07-2020, 10:30 AM
2007 22' International CCD
Corona
I’m thoroughly allergic to mornings. My wife always works nights. Neither of us get up at sunrise anywhere. Even our dogs sleep late on the road...
10-07-2020, 10:36 AM
2019 20' Flying Cloud
Eau Claire
, Wisconsin
Agree
https://www.walmart.com/ip/Camco-451...SABEgKPqPD_BwE
100% agree, it works so well to block all the light and help keep out the hot or the cold. Easy in and out, and not expensive. Don't have the one with foil but probably works just as well. Joe
