Old 11-07-2017, 06:43 AM   #1
Anywhere , Alabama
Possessed Lights
Well this is an odd one,,,,and frustrating. Few nights ago temp was in low 20's. Woke up at 2:00 am to the dinette lights going from bright to dim on their own. Went to light panel to turn off,,,no luck. Went to main firefly panel to turn off,,,no luck. Couldn't get them to stop cycling bright to dark to bright. Finally noticed some condensation on the inside wall around the light panel. Pulled the plastic cover off the circuit board and warmed with a hair dryer. After a few minutes, it allowed me to turn off. Guess we had a drop of water on the circuit board creating a contact. Dang.
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 11-07-2017, 06:49 AM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
The 17 Classic bathroom firefly panel is just under the window, low 20s, condensation, same-o, same-o. A piece of clear tape for a drip awning worked.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 11-07-2017, 12:38 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
A can of silicone lube can also be handy for moisture and circuit boards. Some grab WD-40 since this is exactly what it was originally designed for. Don't mix the two though.
uncle_bob is online now   Reply With Quote
Hitch light possessed! Glowing when off! larry9000 Electrical - Systems, Generators, Batteries & Solar 3 07-18-2017 06:25 AM
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
Surburban Furnace Fan Possessed! Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-13-2012 09:40 AM
suddenly possessed by 58 flying cloud 58flycloud Member Introductions 12 06-15-2010 04:50 PM
possessed heated seats boondockdad Tow Vehicles 2 05-07-2008 08:06 PM
