Old 03-26-2020, 11:28 AM   #1
2018 30' Classic
Traverse City , Michigan
Plugged Bathroom Sink
We’ve always had slow draining of water in our bathroom sink. Now it’s quit totally. We’ve tried the baking soda, vinegar and boiling water treatment to not avail. Any suggestions?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 03-26-2020, 12:05 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Plunger or take the trap apart and clean it
CRH is offline   Reply With Quote
Old 03-26-2020, 12:37 PM   #3
2018 28' International
Fayetteville , Georgia
Take the trap apart and snake if if required
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 03-26-2020, 05:30 PM   #4
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
The waterless trap below comes apart by hand or with minimal tools. When I had that problem the drain came apart by hand. Don’t forget something to catch the water. It ended up being a ton of hair caught in there. Goes back together easy too.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 03-26-2020, 08:39 PM   #5
2018 28' Flying Cloud
Fairfield , California
Agree, remove P-trap under sink by unscrewing the two plastic collars by hand. Will likely find a build up of toothpaste/soap/hair. Take it outside and flush it out. Be careful not to overtighten when reassembling. Because we use a lot less water than sink at home, gunk tends to build up faster.
StuartsDad is offline   Reply With Quote
Old 03-26-2020, 09:02 PM   #6
2012 28' International
Prince Edward County , Ontario
Agree with the above responses. When brushing our teeth, we now spit out the toothpaste into the toilet instead of the sink. The most recent blockage wasn't the P-trap but stuff caught up under the sink stopper. We pulled it out and cleaned it and it now drains fine.
Cyclist is offline   Reply With Quote
Old 03-27-2020, 05:34 AM   #7
2018 30' Classic
Great suggestions. I know what we’ll be doing today. Thank you for your responses.
2018 30’ Classic
Old 03-27-2020, 05:53 AM   #8
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
We highly recommend using “Dissolve Liquid Hair and Grease Clog Remover“ from Amazon for $12. Worked for us when nothing else did.
Bruce
2020 23’ Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 03-27-2020, 06:31 AM   #9
2018 30' Classic
I don’t believe the use of harsh chemicals is recommended due to the seals and connections that exist in our trailers. Should be a last cast effort IMO
BigSxyWhtGuy
Old 03-27-2020, 08:56 AM   #10
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Agreed. These chemicals are not compatible with many of the materials downstream of the drain, particularly the rubber seals in the dump valves. Do not do it.
thewarden is offline   Reply With Quote
Old 03-27-2020, 09:53 AM   #11
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Could be a blocked tank vent...these can become blocked with leaves & debris from the roof or the pipe itself can "drop down" into the tank (below the water level) and not allow air to be displaced for the water coming in.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 03-27-2020, 10:26 AM   #12
2018 30' Classic
Shari
On an 18 classic? I guess this is a possibility as well. OP, try to disconnect waterless catch first and then climb on the roof and check stack
BigSxyWhtGuy
Old 03-27-2020, 10:52 AM   #13
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
After the First Time... you will be experienced.
Take a hose connected to City Water under pressure. Have a nozzle on the 'working end' that can be immediately on/off. Like used to water a garden with the pistol grip.
Dampen a towel. Place it around the nozzle to prevent all or most of the water that is not directed down the drain. (Although removing the trap is advised, first, for the bacteria slime that coats a trap and will clog up eventually.) This slime will wash out under pressure. Hot water can distort the PVC in a trailer.
Bathroom sink is not as likely to get a clogged drain like a Shower Drain. Often HAIR. It will stink is your first clue as it is a Bacteria Recreation area.
Let the water pressure... at FULL BLAST. In short bursts at first. Be prepared if the drain is really clogged with something not soft, but a hard clog... stop the water as it will overflow. Then bail it out and start pulling plumbing apart. If the trap is clear... the hose pressure can be used again directly into the PVC pipe.
We rented apartments at one time. A plumber is expensive, as it is always becomes the OWNER's problem... not the people who are renting... kind of thing. That is why they rent...
When you discover what was plugging the sink... don't do that any more. Some lessons are learned, others you will have to pay dearly to discover.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 03-27-2020, 11:12 AM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
FYI/ There is also a gizmo, forgot what it's called, that connects to a hose. It consists of a rubber bladder that fills up with water and releases when a certain amount of pressure is built up. Never used it in an RV situation.
Old 03-28-2020, 06:52 PM   #15
CRH
1995 25' Excella
xxxxx , xxxxxx
It's a drain cleaning bladder. Lowes, Home Depot, Harbor Freight, ect sell them for about 10 bucks
Old Yesterday, 04:34 AM   #16
2018 30' Classic
Thanks to everyone. The baking soda/hot water trick and some minor probing did the trick. Will probably take the P-trap off to just make sure all is cleaned out. Thanks for the suggestions from everyone.
2018 30’ Classic
Old Yesterday, 05:47 AM   #17
Kensington , Maryland
This often works for me:
https://www.amazon.com/Vastar-Drain-...5482408&sr=8-5
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old Yesterday, 06:10 AM   #18
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Thanks, never seen these. Looks very handy for home and trailer.
Larry
lsbrodsky is online now   Reply With Quote
Old Yesterday, 09:59 AM   #19
2007 22' International CCD
They work quite well for standard P-traps. Grabs the hair and soap clog and pulls it right out.
I wouldn’t use it on a Hepvo trap less system out of concern it would damage the flaps.
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 01:14 PM
2014 Sprinter kitchen sink faucet loose from sink base AirHammar Plumbing - Systems & Fixtures 0 11-15-2016 11:11 AM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
Plugged Shower and sink! maggieevans Sinks, Showers & Toilets 12 10-02-2013 01:08 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
