Old 02-13-2019, 12:09 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Panel dent
Well the wind got me. Was opening the door with my hands full when the wind snatched the door away from me with the key still in the lock. Put a small crease in the panel. Is there any way to get the crease out of the panel or am I stuck with looking at this dumb mistake forever?
jlandreth is offline   Reply With Quote
Old 02-13-2019, 01:03 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
No way to really pull a crease out as the alum has already stretched. You may make it look slightly better, but some degree of scar will most likely always be there.
If it bothers you, you can get a panel overlay to the damaged panel, but panel overlay and/or panel replacement are not inexpensive.
Old 02-13-2019, 01:05 PM   #3
Rosieriviter's Avatar
2013 25' FB Flying Cloud
2018 30' Classic
Campbellsport , Wisconsin
Put a badge or something that gives you pleasant memories over the dent to hide your misfortune..
Rosieriviter is offline   Reply With Quote
Old 02-13-2019, 01:13 PM   #4
2019 30' Classic
Good idea. I will have to find something that seems to go with streaming.
Old 02-13-2019, 01:25 PM   #5
2018 30' Classic
Maybe your “Officially Registered “ Airstream medallion would look good.Plus it’s personal
Old 02-13-2019, 01:28 PM   #6
2019 30' Classic
I haven't seen an Officially Registered medallion.
Old 02-13-2019, 01:31 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
There are a few threads that share some ideas about covering blemishes in the skin.
Here's one>
http://www.airforums.com/forums/f381...es-144251.html
Alan
Panel on Panel Repair moosetags Ribs, Skins & Rivets 13 03-14-2019 04:42 PM
Dent Puller? Replace Panel? mistermike Ribs, Skins & Rivets 15 08-14-2017 07:36 PM
Minor dent in center roof panel ghatfield Exterior Restoration Forum 10 11-01-2014 04:05 PM
Polishing a new panel to match an Alclad panel 66replica Cleaning, Stripping & Polishing 4 09-13-2014 12:29 PM
Small dent? New panel? sumsmug Ribs, Skins & Rivets 15 09-19-2007 01:06 PM
