Old 09-16-2020, 06:35 AM   #1
2020 30' Classic
Lynchburg , Virginia
Noisy Towel Warmer?
Is it normal for the towel warmer to make noise when the heat is on?
HDWells is offline   Reply With Quote
Old 09-16-2020, 09:14 AM   #2
2020 Classic 33
Box Elder , South Dakota
No.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 09-16-2020, 10:02 AM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Negative. The reservoir for the alde system is in that cabinet above the towel bar. What you are hearing is likely the fluid level is very low and the gurgling of the fluid is occurring. Iíd check your tank and fill with fluid ASAP. If your reservoir is full, let us know and it could be something else?
There are no moving parts upstream from the motor, so itís likely the reservoir level.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 09-16-2020, 12:34 PM   #4
2020 30' Classic
I checked the level and it is half way between min and max
Old 09-16-2020, 02:02 PM   #5
2020 Classic 33
When you checked was the system in heating mode or was it cold? Cold you are good, in heating mode at that level you may not have enough fluid. Have you tried following the manual for bleeding air out of the system?
Gary
NōVPN
Old 09-18-2020, 01:56 PM   #6
Mike0392's Avatar
2019 33' Classic
Estes Park , Colorado
Vent
Originally Posted by ghaynes755 View Post
No.
On your 2020 there is a vent on the towel bar . Open the bleed carefully using an old towel and vent the air.
Mike0392 is offline   Reply With Quote
Old 09-19-2020, 05:12 AM   #7
2020 30' Classic
The heat seems to be working.. but when it comes on its agitating in the accumulator tank. so the noise may be coming from the tank not the rack. I did not know the tank was in the wall behind the rack. while warm the tank still appears to be half full and the fluid is circulating in the tank
Old 09-19-2020, 07:03 PM   #8
2018 30' Classic
What previous poster was saying is that if the heating is on the liquid expands and it may appear you have enough liquid. My fluid level is half way between the half mark and the low mark when the system is cold. Have you checked what it looks like when the pump is off and system is cold?
Also, you may be able to lower your pump speed at the alde. I believe mine is set to 2 but Iíd have to pop the seat cushion to verify.
BigSxyWhtGuy
Warmer Lights for Late Models Thiss General Interior Topics 1 06-25-2018 04:59 PM
Lights - Warmer Please boodalu Lights - Interior & Exterior 5 10-20-2010 02:45 PM
secret towel bar? RevBec 1990 - 1993 Excella 10 08-18-2009 06:31 PM
how to remove towel bars? wannaroam General Interior Topics 7 09-19-2007 03:31 PM
Towel rack inside shower? altamont Sinks, Showers & Toilets 1 02-27-2007 05:19 PM
