Old 04-07-2019, 03:51 PM   #1
Paul Kukstis
paul.kukstis's Avatar
2018 30' Classic
Scituate , Massachusetts
No hot water from galley faucet
Just de-winterized my 2018 classic 30RB, having followed all the instructions to winterize it back in the fall.
I have clean water running through the system, hot and cold water in the bath and shower,and cold water in the galley but nothing coming out of the hot side. (Valves are open under the sink).
The Alde heating system is solid.
Any ideas?
paul.kukstis is offline   Reply With Quote
Old 04-07-2019, 08:01 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
What happened when you close the cold water valve on the galley faucet?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-08-2019, 03:35 AM   #3
Paul Kukstis
2018 30' Classic
There was no water flow
Old 04-08-2019, 08:28 AM   #4
2018 30' Classic
Iím certainly no expert but that means you have a valve closed somewhere if there is zero flow with hot open at the faucet but cold closed.
If you have it at the shower but not the kitchen, I would check all your lines again between shower and kitchen as it sounds like the flow runs anti clockwise and something may have failed or was missed in the process.
Iíve never winterized my 18 as we full time. So for no specifics here, just giving my 0.02
BigSxyWhtGuy
Old 04-08-2019, 08:30 AM   #5
2018 30' Classic
Airstream May be able to give you phone support as well if you call them. Youíre still under warranty if something needs to be repaired as well.
BigSxyWhtGuy
Old 04-08-2019, 12:55 PM   #6
Camping Dutchman
2018 33' Classic
Manchester center , Vermont
Kitchen faucet issues
I have the same problem, but mine is on the cold water site. It happened after winterizing. According to JC this can happen and it is something in the faucet itself. I did try to clean the mixing valve, but didn’t solve the issue. I called Koehler and they sent me a new faucet ( under warranty). I still have to replace it. Very difficult in the tiny space under my 2018 classic.
Menno is offline   Reply With Quote
Old 04-08-2019, 03:52 PM   #7
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
2005 25' Classic
1988 23' Excella
Daphne , Alabama
Had the same problem with my Moen faucet in the shower. I found the solution on You Tube and changed out the cartridge in the faucet and that corrected the problem. The cartridges go bad at times and are not cheap.
Beaubill is offline   Reply With Quote
Old 04-08-2019, 05:00 PM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Omen will replace the cartridge free...life time warranty..try unscrewing the wand and cleaning the small filter....that was where our problem was
Old 04-09-2019, 07:13 PM   #9
Paul Kukstis
2018 30' Classic
Thank you all for the responses. Called kohler and they are sending out a new cartridge at no charge...hopefully it will do the trick. This forum, and YouTube, are great resources.
GoStreaminí
Old 03-21-2021, 12:34 AM   #10
Flht2k's Avatar
sacramento , California
Originally Posted by Menno View Post
I have the same problem, but mine is on the cold water site. It happened after winterizing. According to JC this can happen and it is something in the faucet itself. I did try to clean the mixing valve, but didnít solve the issue. I called Koehler and they sent me a new faucet ( under warranty). I still have to replace it. Very difficult in the tiny space under my 2018 classic.
Have you installed your faucet. I also have tight access.
Flht2k is offline   Reply With Quote
Old 03-23-2021, 06:22 AM   #11
Camping Dutchman
2018 33' Classic
No. I had it done by dealer. It was too difficult fir me.
Old 03-23-2021, 09:34 PM   #12
Flht2k's Avatar
Very low water pressure to galley and shower. Toilet and bath faucet work as usual lanewoodwork Sinks, Showers & Toilets 6 08-21-2017 02:24 PM
Galley Faucet and Toilet Sprayer - No Water badib-yazdi Fresh Water Systems 2 04-09-2016 09:03 AM
Galley Faucet mjayjensen Plumbing - Systems & Fixtures 18 01-18-2013 08:10 PM
Moen Puretouch Galley Faucet BoJo Fresh Water Systems 5 03-01-2009 06:44 AM
Replacing Sink and Faucet in Galley 1Michigander Cabinets, Counter Tops & Furnishings 15 04-21-2008 11:35 PM
