Old 02-20-2020, 08:18 PM   #1
2018 30' Classic
Mannford , Oklahoma
Nev-R-Lube axle phaseout?
Needed to replace a wheel hub on my 2018 Classic Nev-R-lube axle. MY A/S
dealers says Dexter will not make the Nev-R-lube anymore, switch the EZ lube design only. Meanwhile, I can't find a Nev-R-hub anywhere. Looks like I may
have to change out axles to the EZ design. Will be calling JC tomorrow to see
if Classic customers are out of luck when Nev-R hubs are needed.
Anyone else hear of this problem?
Gerald
geraldsmith is offline   Reply With Quote
Old 02-20-2020, 08:44 PM   #2
dznf0g's Avatar
Oswego , Illinois
Nope, but concerning..let us know what you find.
-Rich-
Old 02-20-2020, 09:10 PM   #3
2013 20' Flying Cloud
Westerly , Rhode Island
I've called Dexter directly several times with questions and a warranty issue. They always answered the phone. Try calling them.
smithcreek is offline   Reply With Quote
Old 02-20-2020, 11:59 PM   #4
2016 30' Flying Cloud
Byron , California
I don't think the nev-r-lube is all that. Once that bearing cartridge is pressed into the hub it is a one way trip, it ain't coming out. If you have a catastrophic failure that damages the hub/drum like I did it requires all new hubs and bearings, etc at $2000 each axle. I dodged the bullet with warranty, but will be looking to convert to a more traditional bearing set up in the future.
A word of advice to those about to have warranty expire is pay to have brakes serviced and inspected before that happens.
obytheway is offline   Reply With Quote
Old 02-21-2020, 05:27 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I disagree.
Here is the Dexter pdf showing procedure.
http://www.dexterpartsonline.com/fil...20Bearings.pdf
It can be pressed out and replaced. It can be replaced w/o a press with correct bearing pusher-puller tool set. I've done it. This type bearing is used in a very large range of applications. Front wheel drive.
Harbor Freight tool, same as I used.
https://www.harborfreight.com/Front-...-Pc-63728.html
Gerald,
Is the hub casting damaged? Can you post pic please?
Don't give up yet.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-21-2020, 05:58 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Watching with interest...17yrs it's time.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."Molly Ivins
“Growing Old…being able to think about the things you can no longer remember.” RLC
"Never tow faster than your Guardian Angel can Fly"
Tahawus....🌥
Old 02-21-2020, 06:18 AM   #7
dznf0g's Avatar
Oswego , Illinois
Originally Posted by GCinSC2 View Post
I disagree.
Gerald,
Don't give up yet.
Gary
I agree. Not an issue if you have a press. If you don't, its about $80-$120 for a new bearing (depending where you shop) and maybe $20 to carry in your hub and new bearing to a shop with a press.
Automotive 101.
-Rich-
Old 02-21-2020, 12:57 PM   #8
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Automotive 101.
Phew!! The panic was starting to set in. This sounds pretty straight forward.
thewarden is offline   Reply With Quote
Old 02-22-2020, 12:48 AM   #9
Byron , California
Ouch, I was on a trip and a long way from home on a long holiday weekend when my issue developed. AS dealer said bearings couldn't be reused.
Guess I'll change my name to Ben Dover.
Old 02-22-2020, 02:08 AM   #10
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
They're correct. They cannot be re-used. They CAN be replaced easily.
Old 02-22-2020, 11:19 AM   #11
...Without a 'catastrophic failure' photo it's hard to determine anything.
Are we talking,"easy" or "never"
If you are servicing, without such a failure, I'm hoping whatever bearings come on the new 4200#axles can be R&R, re-greased if needed .
New axles this Spring...inquiring mind trying to get it right.
Tahawus....🌥
Old 03-01-2020, 12:13 PM   #12
2016 25' Flying Cloud
Friday Harbor , Washington
Do I need to grease wheel bearing after 3 years in place?
My 2016 Flying Cloud 25 footer has not moved since purchased in October 2016. I live in it. Now it is to be towed about 125 miles to a new location. Do I need to re-grease the wheel bearings? Any advice appreciated. Thanks.
Rob Cope is offline   Reply With Quote
Old 03-01-2020, 12:21 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Your trailer should have the never lube bearings which is a sealed unit. If that is the case, you should be fine.
Richard
Old 03-01-2020, 12:57 PM   #14
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Am I to understand that Dexter no longer sells Never-lube axles and/or cartridges?
guskmg
Old 03-01-2020, 02:28 PM   #15
1976 31' Sovereign
Oswego , Illinois
IMO no rear whl drive autos go 50,00 miles or plus yrs. w/out repacking. This idea of repacking every 3 yrs bunch of hooey.
Old 03-01-2020, 09:35 PM   #16
Bluffton , South Carolina
Interested to hear the answer.
69SoulShine is offline   Reply With Quote
Old 03-02-2020, 12:19 AM   #17
Byron , California
To clarify, my failure was not bearings. They were fine. My failure was both right hand brake assemblies basically coming apart inside the drum during a hard braking incident on the freeway. I didn't realize I had a failure and continued on my way with a bunch of brake parts rattling around in the drum. Mechanic said adjuster was blown apart, actuator arms and magnets broke. Said drums were severely damaged and should/could not be reused.
Problem is bearing cartridge can be removed but not reused. At least that is what I was told. So new drums, new bearings. I was just happy Airstream Seattle took care of me over 4th July weekend and Dexter covered me.
Old 03-02-2020, 05:43 AM   #18
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
I had the same thing happen on my last trip. The brake completely fell apart inside the drum and I drove about 100 miles before I realized the problem. The drum is ruined. I removed the drum, took off the brake assembly, reinstalled the drum and will have JC fix it in late may at my scheduled appointment.
I also had a similar incident on my 2017 FC25FB where the adjuster spring broke then the spring and adjuster were dragging on the brake drum. I just replaced the brake assembly that time without filing a warranty claim.
I wonder if these brake failures have anything to do with the nev-r-lube being discontinued.
2018 Globetrotter 27Q, 36 nights 5,235 miles, 600W Solar - Produced 50 kWh, PD4655L, 6V Batteries, Champion DualFuel, ProPride, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, 400W Solar - Produced 200 kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(Daytona 2/20)
AirMiles is offline   Reply With Quote
Old 03-02-2020, 05:50 AM   #19
GCinSC2's Avatar
A brake spring and adjuster based failure, IMHO is not related to the Nev-R-Lube bearing.
And we have no posted confirmation AFAIK of Nev-R-Lube parts being discontinued. Anyone have specific details by part number of discontinued status?
I just checked, the OP has not been back with any further details to report on his opening post.
Gary
S/OS #001
Old 03-02-2020, 07:35 AM   #20
I did the google....https://www.google.com/search?ei=1BR...Y4LBQIQ4dUDCAo
Tahawus....🌥
Pulling the hubs and bearings on a Nev-r-lube axle Jammer Wheels, Hubs & Bearings 11 12-04-2018 03:06 PM
Dexter Nev-R-Lube Bearing Spare Parts nickmeloy Axles 12 12-03-2016 04:48 PM
Nev-R-Lube Axle/Centramatics Al - K4GLU General Repair Forum 31 03-31-2013 05:26 PM
Dexter Nev-R-Lube Bearing Information nickmeloy Wheels, Hubs & Bearings 2 11-10-2010 07:40 PM
