11-27-2018, 12:32 PM
#861
ObviouslyKnot
KAILUA
, HI
Originally Posted by turk123
I ask if there was a way to test if both electric elements are coming on.
This scenario is while under electric priority. When you turn on the shower boost it shuts off the circulation pump to all the radiators. You are no longer heating the coach. There is a second pump that pumps glycol to the two water storage tanks.
Thx so much for the factory data dump.
You can check your electric elements by looking at the EMS readout with 1 energized, then 2 energized.
No EMS? oh buddy, are you a trusting soul [emoji12] .
Go borrow one from a neighbor till you buy your own to check current draw.
So, the 3020 unit, with Alde Flow, has a separate glycol pump to circulate hot glycol to some separate domestic water heat exchanger/ tanks that is somehow connected with the Flow component? Where did they put all this stuff?
Thx.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
11-27-2018, 08:38 PM
#862
2019 30' Classic
Canfield
, Ohio
Thx.
I was wondering why my dinette seat on that side was a foot higher!
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
11-28-2018, 08:31 PM
#863
1972 31' Excella 500
Grapeview
Originally Posted by Bigventure
Just an FYI on hydronic heating systems you want the pump speed low. High speeds are bad for a number of reasons. I have seen 1 grain of sand wear out an elbow.
The pump setting for our 3010 came directly from my conversations w/Alda.
Best regards and safe travels.
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
12-21-2018, 10:17 AM
#864
2018 30' Classic
Mannford
, Oklahoma
Century vs Alde transfer fluid
I have bought Alde transfer fluid in a 1 liter bottle from my Airstream dealer. I placed another order a few weeks back and instead of 1 liter of Alde branded fluid, the A/S dealer sent me a gallon of the following:
Century Transfer fluid labeled solar and hydronic system antifreeze.
Inquiring why they sent that instead of the "Alde" branded fluid, the parts guy said it was the same thing.
Not trusting that, I called Alde and talked with Spencer. I sure did not want to mix non compatible fluid. I sent a picture of the label and Spenser said that the Century fluid is OK. In fact, he said Century made the Alde fluid for them. The only difference is the Century is green and Alde is blue. Here is the link for what I am talking about.
http://www.centurychemical.com/produ...ransfer-fluid/
12-21-2018, 11:16 AM
#865
ObviouslyKnot
KAILUA
, HI
Thx for the inside scoop; nothing like a bit of truth to open some options.
12-22-2018, 03:01 AM
#866
Summerville
, South Carolina
Does anyone know the quantity of Alde fluid it takes to replace the fluid in the system? Many of us are coming up on the 2 year recommended fluid change out. Has anyone done this yourself?
12-22-2018, 06:41 AM
#867
ObviouslyKnot
KAILUA
, HI
When I asked JC, a couple months ago, was told about 5 gallons. I didn't get to it before winter storage, but plan to in the late spring.
He said it seemed like a lot for the loop, but the registers are multi-pass, not just straight through. But, there are two model years past the '17s we have, so who really knows.
Any of you over-acheivers out there could really help the rest of us '17 DIY-ers get 'er done with some shade tree stories.
What I've used for make up and plan to use for replacement. It matched the MSDS from Alde for the blue stuff. Pricing is going to drive the concentrate or one gallon premixed.
Camco 35116 Boiler Antifreeze... https://www.amazon.com/dp/B004804N7E?ref=yo_pop_ma_swf
12-22-2018, 05:35 PM
#868
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian
, Idaho
Century Transfer Fluid is available on Amazon for $25 a gallon or $16 a quart for concentrate.
https://smile.amazon.com/gp/product/...ED39JHPWFZ4AH9
James, Your camco link did not work when I tried it??
12-22-2018, 05:58 PM
#869
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian
, Idaho
On my 2018 30' with a 3010 boiler they put the Alde Flow between the boiler and the outside wall. Snug but it works. No difference in dinette seat heights.
12-23-2018, 07:38 AM
#870
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
In this case, if you are going with a concentrate, mix it with distilled water. Trusting the local tap water to be devoid of something nutty is not a good idea. The local grocery store should be well stocked with gallon jugs ....
12-23-2018, 07:41 AM
#871
ObviouslyKnot
KAILUA
, HI
Absolutely, and everything including hands needs be clean, clean, clean when refilling.
12-24-2018, 06:14 AM
#872
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
One unanswered question - do you do a flush before you do a refill? If you flush, what do you do it with and how much of it?
Yes, I know people who get obsessive about oil changes and can't understand why the rest of the world does not do a rinse step.
12-24-2018, 09:12 PM
#873
2018 33' Classic
Silverdale
Had my system flushed by my local AS dealer and Alde, DI water was used. Not sure if a flush is recommended or required prior to replacing glycol, Spencer at Alde could answer this question.
01-11-2019, 05:55 AM
#874
2018 30' Classic
Traverse City
, Michigan
I’m so confused by so much information. We’ve had our 2018 30’ Classic for about a year and a half. We’re currently in FL during a real cold streak. When the heat is on we’ve always heard some “gurgling”. Now when the heat comes on it sounds like it’s raining in various areas. Wakes me up at night. Is this normal?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
01-11-2019, 11:41 AM
#875
ObviouslyKnot
KAILUA
, HI
(Ms. Lauri, coffee alert)
Well, it could be normal if you are a light sleeper
The gurgling you might hear when the circ pump runs for heat is the expansion tank in the cabinet above the toilet (circa 17). If you top it off, less gurgling, but still normal. Sort of a cold weather ambiance to let you know all is well with heat.
The raining sound is new; could be an air bubble in the register near your bunk. AS told me they were multiple pass registers, hence the 5 gallon volume for a 70' loop. So, this will mean 3 passes thru each register, 2 internal elbows, and perhaps you hear the ambiance of the Alde waterfall.
Or it was just raining outside.
The real question was were you comfortable (temp wise)?
01-11-2019, 11:58 AM
#876
ObviouslyKnot
KAILUA
, HI
Originally Posted by cbburke
Yup, looks like they dropped it. I've bought it at RV shops at about $15 a quart concentrate. It was CAMCO 35116 Boiler Antifreeze Concentrate.
01-12-2019, 03:43 AM
#877
Reads a lot
Titusville
smkovalchik, ditto what James said. Try topping off the tank first then maybe bleed the valves nearest to your pillow. (Although I haven’t ever heard the gurgling in the bedroom I can hear the tank when I’m sitting at the dinette.) If you’re still hearing the sound after toppling of the tank you may need to bleed all the valves but I’m guessing that just filling the tank will do the trick.
Lauri
She Believed She Could so She Did.
01-13-2019, 09:29 AM
#878
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
If it's really quiet out and you are in the bunk on the side by the bathroom, you can indeed hear the gurgle in the bathroom tank from bed. Indeed, we keep the bathroom door open at night due to multi dog traffic issues in the hall. That may have some bearing on the noise level.
01-14-2019, 04:26 AM
#879
2018 30' Classic
Traverse City
, Michigan
I think I need to clarify our issue. The gurgling isn’t just in the bedroom and certainly not under my pillow, it’s coming from most of the heating areas, living area and bathroom. The solution is to have it serviced when we return from a Florida.
Thanks for everyone’s help.
2018 30’ Classic
01-14-2019, 05:50 AM
#880
ObviouslyKnot
KAILUA
, HI
Gr8, please post the "rest of the story" about the rainfall noise. Thx.
