03-31-2018, 05:11 AM
#41
ObviouslyKnot
KAILUA
, HI
Mojoe, how did you verify the stud didn't bottom out inside the lug nut?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
03-31-2018, 05:23 AM
#42
Green Cove Springs
Removed the nut, per the instructions and looked inside with a flashlight for any scaring. The cone shaped seat also had scaring which would indicate it bottomed out against the wheel when I torqued them. I also sent pictures to McGard of the two side by side as you can see from first post on this issue and they were confident these were the correct ones. Beyond that, I don’t know any other way to verify. Also, an older thread on this issue got me started on this part number and another poster on this thread also mentioned the same part number for his trailer.
All that said, I would welcome any information to the contrary as I certainly don’t want to make a mistake, personally, nor be recommending a bad part number. So, I believe each person should do there own research to verify the correct part number for their own piece of mind.
Breathe In, Breathe Out, Move On
03-31-2018, 05:30 AM
#43
Green Cove Springs
Originally Posted by Tyvekcat
Yeah, I swapped out the lugnuts on the AS also, after reading another thread on here somewhere about the silly two-piece ones. The good thing is, both Jeeps use the same McGard lugnuts, as the AS, 64010. I have been swapping those out on the 2016 wrangler.
On the older 98 wrangler, they still look good as new. I had replaced those way back in 03.
Good stuff. Made in the USA.
Have a good one.
Just to verify...you installed the 64010 McGard’s on your Airstream, correct? I just don’t want to be giving out (or using!) the wrong part number. Having a little verification would make me feel a lot better.
04-02-2018, 09:19 AM
#44
2014 28' International
Blacksburg
, Virginia
McGard 64010
Just saw your post, Mojoe. Yeah I used the McGard 64010 on my AS.
2014 model, 28' International with the modular aluminum wheels, the 15 inch ones, with the circular holes
That part number(64010) of the McGard lug nuts fits just fine. I never tried metric.
I have them on the Jeeps, the AS and I even put them on my enclosed motorcycle trailer ( which wifee calls furniture hauler) .
They won't fit on the Mini Countryman nor the D-Ram.
I don't think they bottomed out on the modular type wheels. Next time I am out at the storage unit, I will check one of the lugs. I have to move it anyhow.
Hope this helps, you're good,
Best
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
04-02-2018, 09:30 AM
#45
2016 28' International
Sioux Falls
, SD
McGard 64000 are a 13/16" hex 1/2x20 and 1.5" long
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
04-02-2018, 02:57 PM
#46
Green Cove Springs
Lug Nut Safety Issue
The 64010 are 3/4” hex and 1.45” long, so only .05” difference. Both have 60 conical seat.
04-02-2018, 03:11 PM
#47
Sioux Falls
, SD
Allows for 1 more full turn so people that have bottomed out this eliminates that.
04-02-2018, 03:31 PM
#48
Green Cove Springs
Got it. I just rechecked mine yesterday and measured the depth. Seems to be just fine. I intend to pull it for 25 miles or so just to test it then re-torque to be sure.
04-02-2018, 03:36 PM
#49
Sioux Falls
, SD
Excellent, hope it works for ya!
04-02-2018, 04:47 PM
#50
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Check at 25 miles, then 100 miles, which is what the factory suggested after rotating our wheels
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
04-12-2018, 09:36 AM
#51
ObviouslyKnot
KAILUA
, HI
What i found on my '17 Classic, Oct '16 build. McGuire 6400 1/2"
04-12-2018, 09:52 AM
#52
2013 30' Flying Cloud
Kingwood
Replaced lugs
McGard 64010 on left OEM on the right.
04-12-2018, 03:54 PM
#53
Sioux Falls
, SD
How did they work for you?
04-12-2018, 05:11 PM
#54
Kingwood
Lug nuts
Perfect fit and another traveling possible issue off my mind. First trip next week. I’ll report on the re-torquing as we travel.
04-12-2018, 05:45 PM
#55
Sioux Falls
, SD
Excellent, mine along w/new wheels n tires go on first wk of May.
04-13-2018, 03:55 AM
#56
2009 25' FB International
2018 27' Globetrotter
Tavares
Are all new AS since you build date using solid lug nuts?
Thanks!
04-13-2018, 06:16 AM
#57
ObviouslyKnot
KAILUA
, HI
Thanks!
No way to know, without looking. Seems you could see the McGuire name and number even if installed.
With just in time supply chains, one can only assume that parts such as these are subject to using alternative suppliers when something upsets the apple cart outside the fence line.
04-14-2018, 05:38 AM
#58
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I went with DP. Quality seems very good. (As well as I can tell with a naked eye.)
Had four of the 20 that had split. Pics show splits, and side by side with the DP.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
07-29-2018, 10:31 PM
#59
2016 30' International
redondo beach
Working on the stupid Airstream lug nuts today and I discovered how cool a battery impact wrench is.
I have a DeWalt 1/2 drive and that is one sweet tool!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
07-30-2018, 12:59 AM
#60
Salem
, Oregon
Use the correct socket.
Hi, I bought and use two sockets for my tow vehicle and trailer and have never had a problem. Although one shop used an in-correct socket once and slightly tweaked a few covers.
3/4" / 19mm 1/2" drive, deep, thin wall, six point impact socket.
13/16" / 21mm 1/2" drive, deep, thin wall, six point impact socket.
Fat sockets won't fit in the wheel hole correctly and short sockets don't grab enough meat on the lug nut causing the shell to crack and/or slip.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
