Ours have worked fine. I am guessing you are talking about the two sets of lights? The ones over the couch in the front and the ones over the bed(s) in the rear.
Yes, I had several lights that stayed on when the cabinet or closet door was closed. I placed plastic stick on dots on the door where the plunger touched the door to fully disengage the switch. You can buy these at Walmart or Home Centers. This worked for a while, then some of them would fall off. When I was at JC this summer the Tech glued and screwed wood blocks on the doors, which seems to be a more permanent solution.
