Old 04-13-2023, 10:55 AM   #1
2016 30' Classic
Houston , Texas
I have a 2016 Classic rear bedroom rig. Need to check the two fuses on the brake disconnect relay as the LED light on switch panel near the door in out but the relay still operates.
Please help: where on the rig is the location of the relay/solenoid? Thank you
dhroberts is offline   Reply With Quote
Old 04-13-2023, 02:31 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Doesnt that panel just connect to a box under the kitchen drawers?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-13-2023, 04:48 PM   #3
2016 30' Classic
Houston , Texas
I found battery disconnect relay (solenoid) in the front of the rig under the couch.
Most importantly, I found one of the two 5 amp fuses (green wire) located on the relay / solenoid unit to be blown. Once the fuse was replaced, the LED light on the Intellitec battery disconnect switch panel (located near the front door) now works properly.
Per discussion with Chris @ Intellitec's tech support vendor M&M RV Electronics, the relay's green wire & fuse only impact the switch panel's LED light, not the operation of the relay / solenoid.
Old 04-13-2023, 05:48 PM   #4
North AL , Alabama
Was the fuse installed on the solenoid or inline on the wire?
Tyler2you is offline   Reply With Quote
Old 04-14-2023, 06:03 AM   #5
2016 30' Classic
Houston , Texas
There are two 5 amp fuses built into the top of the relay / solenoid housing. A red wire connects to the relay and to one fuse; a green wire also connects to the relay and to the other fuse. The fuses are not found along the wires.
Old 06-29-2023, 02:00 PM   #6
Chesterfield , Arkansas
Location of solenoid
Where can I find the solenoid for a 2016 Airstream Pendleton?
squirower is offline   Reply With Quote
solenoid for battery disconnect switch Xterra Sprinter and B-van Forum 5 12-02-2023 06:43 PM
On Demand Timed relay & solenoid valve s1000pre Plumbing - Systems & Fixtures 1 01-07-2023 07:11 PM
Location of battery disconnect solenoid 29rivets 2020 And Newer Caravel 6 01-10-2022 11:13 AM
Battery Disconnect Relay location Campingchloe Electrical - Systems, Generators, Batteries & Solar 2 06-29-2021 02:18 PM
Battery disconnect solenoid bad denali Batteries, Univolts, Converters & Inverters 11 09-12-2013 08:31 AM
