11-22-2020, 12:12 PM
Ruffin It
2018 30' Classic
Tryon
, North Carolina
Lithium battery placement
I tried looking for related threads but didn’t find this specific question.
I am wanting some input on placing two lithium batteries and a inverter charger underneath the bed on a 2018 Classic 30 rear queen bed. I will be putting this at the end of the bed storage closest to the axles. The total weight is approx. 165 lbs. I will also be leaving the Factory AGM batteries in the battery box on the tongue. My concern is not being too heavy, the concern is weight distribution and how it may affect the structural integrity and towing characteristics. thanks in advance for any experienced replys.
11-22-2020, 08:39 PM
2018 30' Classic
Thousand Oaks
We are adding solar to our rig and likely gonna place 4x lithium batteries under the bed. Only real place we can do it unless we eat up closet space. I am not concerned about the weight but I’ll follow this thread and see what people say.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
11-23-2020, 06:51 AM
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte
You do need to be mindful of reducing tongue weight as it will have an effect on towing stability. I would not think 165# would be significant but four batteries and a large inverter might. Before you spend a great deal of money and end up with a towing problem, estimate the added weight behind the axles (and lowered weight in front of the axles), buy a few 50# bags of sand to throw on your bed, and go for a drive.
PLane,
I have not seen a charger that will appropriately charge a mixed technology battery setup that you describe. What are you going to do to charge the two different types of batteries?
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
11-23-2020, 07:38 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Under the bed is a perfect place as long as you are ok with the loss of the storage. On the classics that’s about the best place to put them.
11-23-2020, 08:06 AM
Naples
Under the bed is a good place unless you want to go below your front couch. I have done this in several 30 foot classics with great results! It's really where you feel it most comfortable.
lewster
11-23-2020, 08:10 AM
2019 27' International
Western NC
, North Carolina
Why are you setting things up with 2 charging systems etc. I think you’ll have a much better system is you bite the bullet and make all 4 batteries lithium. Battle born makes a battery that drops in the factory bald with built in heaters. (I have them)
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
11-23-2020, 09:21 AM
2017 22' Sport
NCR
, Ontario
up front and inside. the Lion do NOT vent, thus no health issue inside
the Lion are MUCH lighter that lead acid.
this also help to reduce tongue weight as it moves the weight close to the AS wheels
11-23-2020, 09:31 AM
2016 30' Classic
Houston
We placed our 600 amp hours of cells under one of our dinette seats. Didn’t want to use the space under our bed. Eliminated the OEM batteries in the tongue box. Conveniently, we had a plug connected to the lithium cells positioned in the tongue box - permits ready access to power for electric air pump, etc.
11-24-2020, 05:10 AM
2018 30' Classic
Lake Charles
, SW Louisiana
We pretty much have the same set-up battery-wise as done by AM Solar in our 2018 Classic M30 RQB whereby we eliminated use of the AGMs up front and had our 400Ah LifePro Lithium battery bank installed underneath the forward dining booth seat cushion along with the BMS, etc..
We now use the A-frame battery box for storage of our extended reach propane hoses and a heavy security chain & lock (we use to lock our Propride hitch OCLs together for security when leaving the AS unattended).
"Finding the Roads that Await Us!"
Rick & Lydia Williams
11-24-2020, 06:31 AM
Ruffin It
2018 30' Classic
Tryon
, North Carolina
I wanted to clear up my original posts. When I stated I would leave the AGM batteries in the front battery box, I should have added that they would be disconnected and used as ballast to offset the 165 lbs. going under the bed. I would much prefer to place this equipment farther forward so I am very interested in the responses received so far. I did think the one dinette seat might be an option. I am also very interested in how the Lewster fit batteries and inverter under the front reclining sofa.
11-24-2020, 08:12 AM
Naples
It is really not that difficult to place a solar control system with a Victron inverter and up to 400 A/H of LifeBlue batteries below your front sofa. I can tell you how or do it for you! Please get back to me at 4rvsolar@gmail.com for more information.
lewster
