Old 01-04-2019, 08:29 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Level Placement
Picked up our 2019 30' Classic today and have spent this afternoon and evening getting familiar with how everything works. I am thinking that I might use an old fashion level when setting up but was wondering where the best location is to put it. I was thinking about putting it on top of the lp gas cover but was wondering how level it is since it's removable. Any suggestions about accurate leveling?
jlandreth is offline   Reply With Quote
Old 01-04-2019, 08:50 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
If you are talking about one of those large bubble levels, if possible, put the level where you can see it from the driver's seat. That will save a lot of steps each time you back in. I suggest you should place it somewhere on the body, a place that will not be removed for maintenance or service.
Alan
Old 01-04-2019, 08:52 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Hereís what we use.
ID:	331095   Click image for larger version
Old 01-04-2019, 09:01 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
that's where mine is too
Alan
Old 01-05-2019, 05:02 AM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I use a Levelmate Pro in conjunction with Anderson Levelers.
Note: you first need to use a carpenter's spirit level to get the rig level in order to calibrate the Levelmate Pro. I use the level in several places - floor, countertop etc. (You would need to use a level first, even with the device mentioned above in order to get its placement calibrated.)
Procedure: Place the levellers under the low side wheels and move ahead (or back) onto the levellers until left/right is showing level. When you put the TV in park the rig may move a little, and go out of level, so I often move the low side a quarter of an inch high and then go into park. Chock the wheels (both sides) before using the tongue jack to remove the coupler from the ball. Remove the safety chains last thing and move the TV out of the way.
Use the tongue jack to get the fore/aft level.
Now calibrate the Levelmate Pro using the app.
There is a module that I permanently mounted under the sink that sends level information to an app on my iPhone. Turn it on and it shows which side is low and by how much on the app.
Next time you can just use the Levelmate Pro from your TV and level your rig single handed.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 01-05-2019, 05:22 AM   #6
Cave Creek , Arizona
+1 on Adventure ASís advice. I mounted the module behind the TV by the dinette- easy access for install and when you change the battery
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 01-05-2019, 05:38 AM   #7
Long Island , New York
Getting the Airstream "level" is easy to over-think IMO. As your owner's manual should explain . . . if the trailer feels level as you walk down the hall, it is level enough for the fridge to work right. Older fridges required more precise leveling, and that outdated thinking is still rumbling around.
After a while, you will get used to eye-balling each site you pull/back into, such that you can pre-determine the leveling blocks you will need under each set of tires. After pulling onto the blocks, we use a short builder's level right on the floor at the main entry door. This way you can stand on the ground and assess things both fore/aft and L/R.
FYI the search function in the blue box above [desktop version of site] works great:
"fridge level" -- https://www.google.com/search?q=frid...=airforums.com
"Keep It Simple, Stu"
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 01-05-2019, 06:06 AM   #8
Originally Posted by OTRA15 View Post
Getting the Airstream "level" is easy to over-think IMO. As your owner's manual should explain . . . if the trailer feels level as you walk down the hall, it is level enough for the fridge to work right. Older fridges required more precise leveling, and that outdated thinking is still rumbling around...
I want to get the trailer level for comfort while sleeping more than levelling the refrigerator.
The LevelMate Pro is also excellent when trying to find a level spot in a pull-through site or parking lot when not using levelling blocks if not unhitching for the night. You would be surprised at how slopped parking lots are when trying to find a spot at W..Mart for the night.
Even if unhitched I will sometimes use the tongue jack to get for and aft level if possible. On occasion I have had to change the 'head' of the bed from one end to the other so my head is higher than my feet for sleeping.
To me, comfort is more important than KISS.
Ray B.
Old 01-05-2019, 06:23 AM   #9
2018 30' Classic
Callao , Virginia
We have a 2018 classic 30 RQB and carry a four foot level for our setup. Back trailer into position, open entrance door and place level on the floor for a side to side measurement. Went that is complete, unhook from TV and level front to back. Works for us!
Airhead2018 is offline   Reply With Quote
Old 01-05-2019, 06:32 AM   #10
Of course you cherry-picked a partial quote of mine to make your point, Ray.
I went on to describe in Post #7 using a small builder's level to get the trailer level [enough], and it would be very difficult for anyone sleeping to notice an out-of-level condition using this KISS solution.
Really . . .
[end of discussion]
Old 01-05-2019, 06:44 AM   #11
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Before buying and installing the big level on the front of the trailer, look at how much area is obscured by the 40 pound tanks, and their cover...
Pull out your smart phone, go to the level app, and place the phone in the main doorway floor.
In reality, the fridge is arguably the most critical, but taking everything out of the freezer to place the phone there would be too much trouble.
Depending on how elaborate you want to get, some level apps will share between devices, so you can see how level your wife's phone is in the trailer, while you look at the reading on your phone in the truck.
BTW, is the grab handle light still working?
Old 01-05-2019, 07:03 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
With the 63 Safari and it's finicky fridge I put my 12" level in the freezer for fore & aft and on the floor for port & starboard.
"Cloudsplitter" is not as sensitive so we just level on the counter 'til it feels good. 😏
Obrigado, ť hora de descansar.
Tahawus
Old 01-05-2019, 07:05 AM   #13
1993 21' Sovereign
Exactly. Sometimes "level" is overrated.
Old 01-05-2019, 07:18 AM   #14
2007 31' Classic
Gulf Breeze , Florida
Really . . .
[end of discussion]
I use the iPhone level app. Works great. Just lay the phone on the floor and center the bubble in the bullseye.
trumpetguy is offline   Reply With Quote
Old 01-05-2019, 07:20 AM   #15
Not having a level head, I'm not allowed to determine when the AS within spouse specs. 😘
Tahawus
Old 01-05-2019, 07:33 AM   #16
Tuco's Avatar
1988 32' Excella
Ojai , California
Since the refrigerator is the most sensitive to level, we use a small bubble level to make sure the fridge is as close to level as we can get within reason.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 265k+ (The Beast)
Tuco is offline   Reply With Quote
Old 01-05-2019, 07:58 AM   #17
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
The shower must drain above all else.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 01-05-2019, 01:22 PM   #18
Mollysdad's Avatar
I carry a small torpedo level. Iíve found the floor, table, countertop, and fridge are all different. I put the level on the floor inside the door to rough in the side to side level. Since I have the Husky 5000 I do the front back level from inside with the remote.
Old 01-05-2019, 01:36 PM   #19
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Us too. We usually put the level on the floor between the twin beds. That's where it counts the most.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 01-05-2019, 01:39 PM   #20
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My goal when setting up is to have the cook top level. I hate for the liquid (egg) to run to one side of the frying pan!
Even though I have the big bubble on the front of the trailer I don't use it. I pull the trailer into the approximate location I want to park it. Then I use a torpedo level to one side of the cooktop on the counter top to estimate how much blocking I need on the low side of the trailer. Once the blocking is placed and the trailer tires on top of the blocking I use the same level on the countertop in front of the cooktop to level front to back with the tongue jack. Keep that frying pan level!
Alan
No kidding. How level is level? upnorththree Towing, Tow Vehicles & Hitches 19 03-25-2017 01:14 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
Extra Battery Placement JaceBeck 1997 - 1999 Safari 16 10-02-2002 01:03 PM
