Old 07-15-2020, 06:32 AM   #1
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
length of 50amp cord for 2018 Classic
Hi all,
We're picking up our classic tomorrow and we're going to be staying on a friends property who has 50amp service.
Question is we don't know if we need to buy an extension cord.
Can anyone help us know the length of the 50amp cable that comes with a 2018 Classic 30RB?
thanks
Dave
davcarv is offline   Reply With Quote
Old 07-15-2020, 06:53 AM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I just measured mine for you and it is 37'
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 07-15-2020, 07:25 AM   #3
Long Island , New York
If you need to go longer than that 37' OEM cord, you should upgrade to a lower AWG [American Wire Gauge] number cord/cable for larger diameter wires inside. Do you know the total "run" you need from the trailer to your friend's outlet? Keep in mind that any new inline plugs/connectors will affect your available amps and possibly voltage.
Lots of factors to be considered if the total run is high IMO.
Let the music lift you up . . .
OTRA15 is online now   Reply With Quote
Old 07-15-2020, 09:48 AM   #4
2019 25' Flying Cloud
Hendersonville , North Carolina
Friends 50 AMP Service
You probably already know this but make sure that 50 AMP Service is 110/120 Volts and not 220 Volts.
Would not want you to fry the electrical system of your new Classic.
Congrats on your Classic!
uraljohn is offline   Reply With Quote
Old 07-15-2020, 08:41 PM   #5
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Thanks for replying to my post
Follow up question
If the service was 220 would’t the coaches breakers do thier job and trip? And protect me?
Old 07-15-2020, 08:51 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Originally Posted by davcarv View Post
If the service was 220 wouldít the coaches breakers do thier job and trip? And protect me?
No.
50A RV service is 2 legs with 120v each @50A each with a common neutral.
Drive 240v bonded to your trailer and kiss 120v electronics, air conditioners, converter, anything 120v powered goodbye. Breakers protect wiring against current not voltage.
In reality this will never happen unless you hire a completely inept electrician to wire a ď50AĒ outlet for your trailer at Home off your main panel and they donít wire a NEMA 14-50 outlet correctly. This is an edge case - almost never happens although there are some reports on the form of this
Iím not an electrician and even I was able to wire a 14-50 outlet correctly for my electric car charger..........
wulfraat is offline   Reply With Quote
Old 07-15-2020, 09:06 PM   #7
2007 22' International CCD
The real danger is the electrician that wires an RV-30 120 volt only receptacle like an obsolete three/wire electric stove outlet, putting 220 volts from hot to neutral on the trailer. Yup, smoke does leak out when that happens.
They donít look at the diagram on the box the receptacle comes in because ďthey know what they are doing...Ē instead of thinking first.
Thatís why I wire my own. I think about what Iím doing first before I just wire it up. .
Old 07-15-2020, 09:27 PM   #8
2017 28' International
Jim Falls , Wisconsin
You don’t want to get 1 longer cord. I bought an extension 50 AMP cord for when we stay at son’s place. We just leave it there, because frankly you will seldom if ever need it. Also remember to cover over the connection with an extension cord. If it rains it will blow the breaker. We learned the hard way.
Just a suggestion: Get a shorter 50 AMP cord. You are going to hate using that 37’ cord all the time. It is a bear to get in and out; especially when it is cold. I keep mine with me just in case. Using the 15’ 50AMP is a breeze.
Daquenzer is offline   Reply With Quote
Old 07-15-2020, 09:36 PM   #9
wulfraat's Avatar
Originally Posted by Daquenzer;
Just a suggestion: Get a shorter 50 AMP cord. You are going to hate using that 37í cord all the time. It is a bear to get in and out; especially when it is cold. I keep mine with me just in case. Using the 15í 50AMP is a breeze.
^^^ X2.
I have a 15í flexible 50A Mighty Cord with 10í extension for my 30í trailer. I canít actually remember the last time I used the extension.....
The stock power cord that air steam ships is a beast to handle. Just wait until it gets cold outside and it basically becomes a brick. Sold mine on Craigslist.....
Old 07-16-2020, 07:16 AM   #10
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Originally Posted by wulfraat View Post
^^^ X2.
The stock cord IS a beast. I installed a reel in the rear compartment of my Classic and winding that cord when it was cold was horrible! Two person job.
At the suggestion of someone here I bought a 25' mighty cord (50a). It can be wound much tighter and bends so much easier when cold.
Here's a link:
https://www.etrailer.com/RV-Power-Co...-5025ED90.html
Old 07-16-2020, 07:51 AM   #11
2020 30' Classic
2019 28' International
Holyoke , Massachusetts
I bought the Mighty Cord too but also bought the extension cord for it since it's shorter than the stock cable.
hsgsports is offline   Reply With Quote
Old 07-16-2020, 08:04 AM   #12
2019 30' Flying Cloud
Grass Lake , Michigan
Originally Posted by Daquenzer View Post
You donít want to get 1 longer cord. I bought an extension 50 AMP cord for when we stay at sonís place. We just leave it there, because frankly you will seldom if ever need it. Also remember to cover over the connection with an extension cord. If it rains it will blow the breaker. We learned the hard way.
x3. We also bought a 15' 50A extension cord with an adapter for the AS marine inlet and now rarely use the factory cord. About 90% of the time, power in campsites is within 15' of the AS inlet.
Adapter: https://www.etrailer.com/Marine-Powe.../CAM55562.html
cord:https://www.etrailer.com/RV-Power-Co.../CAM55194.html
The 15' cord is higher quality than the factory cord and is much more flexible, making it easier to store.
oldenavy is offline   Reply With Quote
Old 07-16-2020, 10:45 AM   #13
1994 33' Land Yacht
APEX , NC
120/240??
No.
240v in the US comes from "2 legs with 120v each" So is the rv panel 120 or 240??
RON NICKELS is offline   Reply With Quote
Old 07-16-2020, 12:08 PM   #14
The circuits in the panel are loaded only with single pole load breakers, so the circuits appliances and outlets only get 120 volts.
They use a panel designed for 240 volt distribution, but wire for 120 volt circuits.
On each 120 volt circuit, the hot lead (black) goes to a breaker output screw, the neutral (white) goes to the neutral buss bar, and the safety earth (ground, green or bare wire) goes to a separate ground buss bar per code.
There is 240 volts in there between the two Ďhotí buss bars, but it takes different wiring (and two breakers) to send 240 to an appropriate appliance. They donít wire for 240 usually.
The power from the shore power input goes to a pair of 50-amp MAIN breakers that feed the two internal hot buss bars in the panel that the load circuit breakers connect to.
In a house, the two MAIN breakers are tied together. This is done to kill all power if one of them overloads and trips. Dunno how a trailer does this, because mine is 30 amp only, with a single MAIN 30 amp breaker. I suspect it is the same way.
Old 07-16-2020, 08:50 PM   #15
1988 32' Excella
Robbinsville , New Jersey
Absolutely WRONG! 50 amp must be 240 volt. Neutral wire can only handle 50 amp so if the two 50 amp hot wires are same leg so they are not 240 volt then you could have 100 amps on the neutral and have a fire.
Old 07-17-2020, 04:55 AM   #16
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Mark Polk describes 30A vs 50A wiring. At about 2 minute mark, 50A is explained that's the good stuff.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 07-21-2020, 07:46 PM   #17
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Hi,
Quick update.
We stayed at our friends place this weekend and used his shore power.
All was well.
Storage for 50amp cord Flht2k 2016 - Current Flying Cloud 9 03-01-2017 02:02 PM
Using a 30amp cord on a 50amp connection Pat Cassity Electrical - Systems, Generators, Batteries & Solar 28 11-05-2015 08:05 PM
Length of standard 30 amp extension cord on trailer Lothlorian Electrical - Systems, Generators, Batteries & Solar 8 09-02-2015 08:56 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
