RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-20-2020, 06:50 PM   #1
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Left side recliner fuse?
The recliner/USB plug for the left side recliner doesn't have power. Sort of a catch 22 that you can't get the recliner up to be able to check the connections unless the recliner is powered.
I am hoping it is a fuse but none of the 12v fuses are labeled. Is the recliner fuses separately? If not, is there any way to get the recliner up without power?
2019 30' Classic RB pulled by 2018 Dodge RAM 3500 short bed
Froglips is offline   Reply With Quote
Old 11-20-2020, 08:51 PM   #2
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
The recliners are not powered from 12VDC. They are powered from 120VAC by way of their own power modules. If you are not plugged into shore power, you need to turn on the inverter to power the recliners.
Also, I have pried my recliners open by hand when unpowered. They are spring loaded in the closed position, but can be pulled open.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 11-21-2020, 02:48 PM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
You may be able to get access to the plug by removing the grate looking things on the back of the couch or the center panel that covers the sub?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 11-22-2020, 05:59 AM   #4
2019 30' Classic
Joe,
Perhaps the 2016 Classic has a different recliner than the 2019. I have pulled very hard and the recliner won't open.
Which 120v breaker operates the recliners?
BigSxyWhtGuy,
I have pulled the center cover. No access. I can see the mechanism when I remove the cover behind the couch. I would need ape arms to reach anything.
Old 11-22-2020, 09:40 AM   #5
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by Froglips View Post
Joe,
The 2017 to 2021 Villa Recliner Couch does differ from the 2015-16 version. The 2015-16 has a wider center section that features a pull out drawer. The 2017-2021 version features a narrower center section that has no drawer, but hides the converter. There are also differences on the armrests and switches that operate the recliners.
The outlet the powers the recliners in on the 120V circuit breaker that feeds the "transfer switch" inside the inverter that allows them to be operated from the inverter when not connected to shore power. Off hand, I do not know which circuit breaker that is in my 2016 (I have labeled them inside the breaker box as they were unlabeled from the factory) but don't have a photo and the Classic is not stored at home. Your a 2019 could be different.
A tripper breaker should be in a slightly different position or try your TV or radio or the outlet under the dinette when plugged in to short power. If they work, the breaker is not tripped and the recliners should work.
Unless at some point (2019+?) the recliners were changed to 12V. We have friends with a 2017 or 2018 Classic (forget which) and I think theirs are still 120V.
P.S. OK, I remember now. I could manual pull the recliner out AFTER I removed the motor because the attachment point for the operating motor cracked off the steel framework under the couch. That's right, the little steel tabs on the steel bar that the motor attaches to snapped off. It has since been fixed. That may have been the only time it could be operated by hand.
Joe
WBCCI/VAC #6768
Old 11-23-2020, 06:45 AM   #6
2019 30' Classic
Joe,
Thanks. The right recliner works so it isn't the 120 volt power supply. I can raise the right (curb side) recliner and see the plug where both recliners are plugged in.
I guess it is off to the dealer unless someone has a different suggestion. My dealer experiences have been less than sterling so I don't relish this trip.
Old 11-23-2020, 09:14 AM   #7
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi froglips,*
Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team to try and help you get this resolved.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 11-23-2020, 09:23 AM   #8
2018 30' Classic
I just opened my side storage to the couch and saw the switch connector to the USB/recliner switch. Have you checked that for power? Or see if your connector may have come loose or disconnected???
Seems like itís in a space that placing something in there may jar it loose on accident eventually.
BigSxyWhtGuy
Old 11-23-2020, 11:21 AM   #9
2020 33' Classic
Sarasota , Florida
We have blown our fuse to our recliners several times. We were shown the fuse under the dinette seat. Itís a 15amp fuse in the fuse panel. We were blowing the fuse simply by using the recline and changing the direction before waiting a couple of seconds before doing so. Hope this helps Bruh.
Gigler is offline   Reply With Quote
Old 11-24-2020, 06:36 AM   #10
2019 30' Classic
Does anyone have the fuse layout for a 2019 Classic 30
The 12-volt fuse panel does not have anything labeled. The owner's manual barely acknowledges that there are fuses. Does anyone have a list of what the fuses attach to?
left side door Germanaussie Windows, Doors, Locks & Vents 6 05-25-2015 09:21 PM
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 08:08 AM
Door on Left Hand Side. Any models? cazna Windows, Doors, Locks & Vents 7 02-10-2012 10:09 AM
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 08:50 PM
Right side, middle of the road, or left of center? DreamStream Off Topic Forum 19 03-02-2004 06:51 AM
