Old 09-26-2022, 10:32 AM   #1
2018 30' Classic
Traverse City , Michigan
Leaking Dometic Toilet
Found water on the bathroom floor this morning coming from the toilet. Fortunately itís fresh water. Took the west off and discovered itís coming from an area right behind the seat attachment. When we step on the pedal to put water in the bowl it comes out of that the highest point behind the seat. Seems to be the water supply. Any suggestions. NO ONE can get us in for a month.
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30í Classic
SMKovalchik is offline   Reply With Quote
Old 09-26-2022, 11:50 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by SMKovalchik View Post
Found water on the bathroom floor this morning coming from the toilet. Fortunately it’s fresh water. Took the west off and discovered it’s coming from an area right behind the seat attachment. When we step on the pedal to put water in the bowl it comes out of that the highest point behind the seat. Seems to be the water supply. Any suggestions. NO ONE can get us in for a month.
You most likely have a Dometic Model 310 toilet. Check this on the sticker on the base below the foot flusher. It's hard to see. Use your phone and take a picture of the sticker.
Once you have determined the model number, look on-line to see how it is configured. The repair should be fairly easy. You may possibly need a new flush valve for about $10. There are many You-Tubes telling you how to do this.
If you have the Airstream dealer do this, it will probably end up costing you the price of two new toilets.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
Old 09-26-2022, 12:51 PM   #3
2017 25' International
West Lake Hills , Texas
And if you need to replace the toilet, it is an easy DIY effort. Takes as much time to unbox and prep as to install it.
Fungus is offline   Reply With Quote
Old 09-26-2022, 12:59 PM   #4
2019 25' Flying Cloud
Houston , Texas
It was the water valve when we had a similar problem.
https://www.amazon.com/Dometic-Sanit.../dp/B004SNJPV0
Quite easy to install.
DCPAS is offline   Reply With Quote
Old 09-26-2022, 01:08 PM   #5
moosetags's Avatar
This is true. I just priced a brand new Dometic 310. It is $205 on Amazon with free shipping. I know because I have priced them and am about to order one for my 2015 25FB.
The dealer may be able to squeeze you in a month from now, keep your Airstream for two months, and charge you $400.00 to fix your old toilet.
Brian
Old 09-26-2022, 01:15 PM   #6
Houston , Texas
This might help.
Old 09-26-2022, 01:56 PM   #7
First toilet delivered from Amazon had a broken hinge. Second toilet delivered from Amazon had a broken hinge but in a different place. Fortunately, my laziness outsmarted poor packaging as I had not returned the first toilet yet. Between the two toilets I could assemble a single perfect toilet. I assembled the broken parts into a single imperfect toilet and shipped the mess back to Amazon.
Old 09-27-2022, 03:31 PM   #8
moosetags's Avatar
That's a funny story. I love it!. If mine arrives broken, I will not be in a rush to send the broken one back
Brian
Leaking Dometic toilet valve DrScotch General Repair Forum 1 06-01-2021 02:30 PM
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 12:38 PM
Leaking toilet Bmtt Sinks, Showers & Toilets 6 05-10-2011 01:09 AM
Toilet Leaking... Need Suggestions samaki Sinks, Showers & Toilets 1 05-14-2010 08:32 PM
leaking toilet jgump Sinks, Showers & Toilets 5 06-02-2008 10:17 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
