Note: This is probably by Blum, or a close copy.
The orange lever unlocks the front of the drawer, and then it slides a bit forward and then lifts out easily. At the rear of each of the drawer slides is a pin that fits into a drilled hole in the back of the drawer. These can sometimes be a bit fiddly to line up when you re-install the drawer. Be gentle with it.
The gray slider part is for fine-tuning the drawer height at the front, it slides fore and aft in the track under the orange lever about 3/4 of an inch or so and levers the front edge of the drawer up and down a total of about 1/4 inch.
