Old 05-13-2020, 04:40 PM   #1
2020 30' Classic
Albuquerque , New Mexico
Jacking
I know not to jack up the trailer using the axle
but am not sure what happens if you do??
What is the proper way to deploy the electric awning? I was told, during the trailer orientation, that before opening, the “close awning” button should be pressed. This procedure prevents awning from having major problems...... But why?
Shinytow is offline   Reply With Quote
Old 05-13-2020, 05:19 PM   #2
2018 25' International
Slidell , Louisiana
The axles are designed to support a mostly balanced and uniform load with the designed lever moments between the wheel and the frame distributed evenly across the axle. They are not strong enough to support point loads from a jack. So jack up the trailer with the jack on a strong reinforced portion of the frame. like where frame components come together.
Pushing the close button first resets the motor positioners so the awning programing opens the awning correctly. Otherwise it can get out of sequence and say hit the door if it's open or try to open too far. This is not mandatory, but it is a good practice that will avoid future disappointments.
Brian
Old 05-13-2020, 05:54 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
I've ALWAYS used the axle mount plate.
Never the 'JACK' point, (that may or may not have a frame on top of it.) On our AS it was about 3" off, not far enough to miss completely, but pretty dam close.🥴
Also used for the jack stands for Winter storage.
ID:	367843   Click image for larger version
Obrigado, é hora de descansar.
Tahawus
Old 05-13-2020, 06:10 PM   #4
dznf0g's Avatar
Oswego , Illinois
^me too. I started jacking at the marked spot one time. Didn't like what I was beginning to hear.
-Rich-
Old 05-13-2020, 06:52 PM   #5
Slidell , Louisiana
^ Oh for sure the axle mount points are reinforced with the vertical plate steel that distributes sheer stress over a long distance. Right on the center of the vertical plate as Bob shows, Very strong there!
Brian
New brake shoes and jacking point wayner1239 Brakes & Brake Controllers 6 04-23-2008 07:03 AM
jacking up 1960 travler 60traveler Jacks, Stabilizers, Lifting and Leveling 3 06-19-2003 05:18 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
