Old 09-02-2020, 11:07 AM   #1
Mike0392's Avatar
2019 33' Classic
Estes Park , Colorado
Inverter
Why does the inverter run on my 2020 classic 33? Itís under my bed and the fan runs unless I kill it at the control panel.. Iím on shore power 50 amp. What does it do? Can I or should I disable it??
Mike0392 is offline   Reply With Quote
Old 09-02-2020, 12:44 PM   #2
2018 25' International
Slidell , Louisiana
The inverters are also sold for use as uninterruptible power so they are designed as pass through for utility power with the inverter in standby ready to switch in less than 2 milliseconds. generally, you don't need this in an RV. It draws about 2 amps from the battery on standby, so I suggest turning it off except when in active use. I keep mine off. It draws nearly 4 amps when on and active with no connected load. It draws 0.02 amps when off
Edit: the inverter provides 120V power for the entertainment system and (very) small appliances when you don't have shore power.
Brian
BayouBiker is online now   Reply With Quote
Old 09-04-2020, 10:57 AM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Are you using cinema mode by any chance? I thought I recalled that this was designed into the trailer to turn that sucker on when on cinema mode regardless of shore power or not.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Flashing inverter light (Multiplex primary panel) inop Inverter ... ScottP Sprinter and B-van Forum 8 12-29-2019 08:37 PM
Question? Replacing factory converter & inverter with 2k watt inverter charger cptdzl Batteries, Univolts, Converters & Inverters 1 06-23-2019 07:55 AM
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
