Old 05-03-2020, 03:33 AM   #1
2018 30' Classic
Lake Charles , SW Louisiana
How to Question: Installing 12v LED light strip in rear cargo bay
I want to install a 12v LED light strip inside of the exterior rear cargo bay located at the rear of my Classic M30 RQB (above rear bumper, below rear window) and am uncertain as to where I can "tap into" an existing 12v circuit.
Anyone done this (I'm sure I'm not the first to think of this or recognize the need for)?
If yes, where did you "tap" to gain 12v+ power feed. I did contact Airstream CS but of course their answer was to run a complete new circuit all the way forward to the 12v distribution panel located below the wardrobe cabinet in the center of the coach (PITA). Given my intended use of the 12v LED light strip will only be when I am accessing the cargo area, I do not see the need to run a complete new wiring circuit and would think there is something far closer to the location that I can tap into.
My plan is to install a 48" 12v DC LED light strip with a button switch activated only when the cargo door is open. (off when closed).
Will appreciate all input.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Old 05-03-2020, 05:29 AM   #2
2018 25' International
Slidell , Louisiana
I tapped into the circuit for the little existing manual light in the corner.
Brian
Old 05-03-2020, 05:34 AM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
This is an easy one... inside your storage area you would have a small light already in place.
Best would be to pull that fixture and access 12 volt power there. If you access or “tap” ithe Power on the “switched” side of that light you can use the current lights switch to turn the new LeD light strip on and off.
Old 05-04-2020, 12:46 AM   #4
2018 30' Classic
News to me! I was unaware a light is already installed in there. It so dark I can barely see inside partially due to our pre-owned Classic already having the Famina bike rack installed on it which makes it a bit more challenging to gain access to begin with. I'll be on the hunt for it now.
Thanks for the prompt replies.
Old 05-04-2020, 12:48 AM   #5
2018 30' Classic
Left or right corner?
Old 05-04-2020, 09:50 AM   #6
callmedave's Avatar
2013 28' Flying Cloud
Cohasset , Massachusetts
Images: 14
Rear storage bay Light
Our 2013 FC28 RBQ has an LED light mounted on the left side.
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
_______________________________
"I prefer someone who burns the flag and then wraps themselves up in the Constitution over someone who 'burns the Constitution' and then wraps themselves up in the flag.”
― MI
callmedave is offline   Reply With Quote
Old 05-04-2020, 10:54 AM   #7
2014 27' FB International
Lewisville , Texas
Smile Rechargeable Led's
I used to hard wire everything no matter how much trouble it was. Then we found these three years ago, they last one to four months on a charge depending on usage.
I have them in the cabinets in the house, my truck cover or anywhere there is a dark place. They just stick on with a magnetic strip and can be removed easily to use as a hand held light too.
Check out these links on Amazon:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
https://smile.amazon.com/Wardrobe-Ox...8610344&sr=8-5
Good luck
NO NOIZE is offline   Reply With Quote
12v
bike/cargo combo rack - rear cargo door window replacement Donna Foxxx Sprinter and B-van Forum 24 06-27-2018 03:30 AM
LED Strip lighting w/ 12v transformer polarlyse Lights - Interior & Exterior 4 11-18-2017 11:38 AM
Awning LED Light Strip factory install silvereagle2 Lights - Interior & Exterior 36 04-19-2016 11:56 AM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
