Old 05-13-2020, 09:31 AM   #1
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Hot water pressure
2018 Classic 33. Hooked up to city water. Pressure from bathroom faucet on hot water about 1/2 that of cold. Pressure at galley faucet ok. Both under sink water valves fully open. The only way to get good hot water pressure at bathroom is to also run water pump. Pressure was fine last fall before winterizing. Any ideas?
DeltaRon is offline   Reply With Quote
Old 05-13-2020, 09:42 AM   #2
2018 25' International
Slidell , Louisiana
Sounds like the faucet has some trash or scale in it at the mixer, you may have to take it apart and clean it or replace it. Could be the block valve under the sink or the tubing that that is uncommon.
Brian
Old 05-13-2020, 09:57 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Every time I dewinterize I have to take the faucets apart and clean out the scale. Usually the screen in the outlet is plugged.
Old 05-13-2020, 01:15 PM   #4
casarodante's Avatar
2012 31' Classic
Another possibility is that the hot water mixer on the back of the hot water heater has a scale buildup. That happened to ours and I had to replace it.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Very low water pressure for hot water from pump barrettjl Water Heaters, Filters & Pumps 21 10-27-2014 07:41 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
