Old 11-24-2019, 08:50 AM   #1
RosieTheRiveted
Tucson , Arizona
Hot water everywhere except the shower
Weíre on a 3-week road trip and for some reason are no longer getting hot water in the shower. Iíve been searching the threads but canít find an answer. Can someone direct me? Itís Sunday so canít call JC, Alex or Koehler for help today.
cniccum is offline   Reply With Quote
Old 11-24-2019, 09:03 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I had that problem and the Moen cartridge in the faucet had failed; Airstream used the cheap plastic cartridge instead of the "forever" bronze version. Not hard to replace...if that is the problem.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-24-2019, 09:46 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Water flows but is not hot or nothing comes out when set to hot?
Old 11-24-2019, 10:47 AM   #4
mpsgolf's Avatar
2015 28' International
Ofallon , Missouri
Sounds like shower control / mixing portion of valve is inop. TU.
mpsgolf is offline   Reply With Quote
Old 11-25-2019, 09:29 AM   #5
RosieTheRiveted
Tucson , Arizona
Fixed shower temp, for now
Thanks all. We were able to dismantle the shower faucet and adjust the screw controlling the hot water flow. The parts are quite flimsy so will be calling Kohler to see if an upgrade is available.
Old 11-25-2019, 09:34 AM   #6
Half a Rivet Short
Hi
The shower faucet is a very normal residential item. You can find them at your local big box store.
Old 11-25-2019, 10:42 AM   #7
Bluffton , South Carolina
Our cartridge failed about 4 months ago. Easy to replace cartridge but had to cut larger hole in shower wall to get steel cap out that covers cartridge. About a quarter inch difference. That was a real pain. JC says they take the whole wall from the bedroom side apart to replace cartridge that seemed even worse. Bought deep hole saw from Amazon and then made a jig out of half-inch plywood to drill through shower stall.
69SoulShine is offline   Reply With Quote
Old 11-25-2019, 10:48 AM   #8
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
You're welcome. Check out my FB page too
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 11-25-2019, 11:52 AM   #9
2019 30' Classic
LEES SUMMIT , Missouri
Sounds like you fixed the problem, but I'm posting in case anyone else has similar problem but not the same cause. I had hot water everywhere in my brand new 2019 Classic EXCEPT in the shower. I was able to temporarily fix the problem by cranking up the mixing valve (under the dinette seat) per the suggestion I found on this Forum. That was a temporary fix in that the main culprits turned out to be both a missing check-mark in the check-box on my Alde system plus a bad shower valve cartridge. After I checked the check-box on the Alde system and Jackson Center replaced the cartridge, the water was so hot that the system was overheating, therefore, I had to turn the mixing valve under the dinette back down. All is good now.
dechampion is offline   Reply With Quote
Old 11-25-2019, 01:58 PM   #10
Mollysdad's Avatar
Step one: Plug the drain so your screws don't make a run for it!
(That's actually a great video!)
Just throwing this out. I saw this tip for enlarging a hole saw opening.
The arbor on a hole saw has enough threads to allow a second saw.
So, put one hole saw on the size of the existing hole, and behind it, the larger one. The first centers the saw (no drill bit needed) and the second cuts.
Old 11-25-2019, 08:46 PM   #11
cniccum. Hopefully that adjustment fixes your problem. It didnít for yours. Ours kept coming and going. Ended up being the cartridge and when I spoke with Kohler they had replaced our model cartridge with a new (improved model) because of that she sent it out for free. Just in case you end up in the same situation here is a picture of ours before I enlarged the hole to get cap out from over cartridge. Again I hope this is not your case. But if it is that steel cap has to come out before cartridge can or bedroom wall has to. Poor design in my opinion!!!
ID:	356863   Click image for larger version
Old 11-25-2019, 09:00 PM   #12
Molleysdad. That’s a great solution but wouldn’t work in my case because the smaller hole saw would hit the steel cap before larger one reached shower wall. But I will remember that for the future. Thanks
Old 11-25-2019, 09:12 PM   #13
This is the hole saw that I used. Was not a pleasurable experience but beat taking out two wall cabinets and bedroom wall!!!
great water pressure except in kitchen FranM Fresh Water Systems 7 07-24-2018 05:15 PM
Water, water everywhere Greg-the-New General Repair Forum 9 03-26-2015 11:14 PM
New owner.. Everthing great except the water heater! airtwins Water Heaters, Filters & Pumps 13 09-17-2011 07:37 AM
Water, water everywhere! janmarie Fresh Water Systems 11 09-07-2010 09:14 AM
Water Water Everywhere dijer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 06-24-2006 12:39 PM
