Old 08-06-2017, 08:39 AM   #1
Quilts&Brews
Marlton , New Jersey
Hot water draining issue ....
Good morning all ....
I have a 2017 Classic J, we have enjoyed this comfortable unit 5 times since purchasing new. I am in Wisconsin on a trip and have experienced an issue with water drainage under the hot water heater.
What I am experiencing is when I hook up the city water, water starts to drip from the white tube under their heater, nothing from the red tube.
All valves appear to be turned on and off approximately, since I have not touch either of them since our last trip when we did not have this issue.
Any answers, I have called my dealer and they are puzzled also.
Thanks in advance
Jed
Pops1814 is offline   Reply With Quote
Old 08-06-2017, 11:23 AM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
The boiler safety valve discharges through the red line, and potable water lines in the area drain through that white line. Cycle the 1/4 turn drain valve under pressure to try flush. Doesn't leak with pump, maybe due to lower pressure. Your built in regulator for city water supposedly set for 60 psi. How's the difference at the tap for city vs pump?
Lots of good info on the 17 Alde system in Much To Do About Alde.
Cheers, James
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 08-06-2017, 11:37 AM   #3
Quilts&Brews
James .... thank you
Old 08-06-2017, 04:24 PM   #4
Reads a lot
Titusville , Florida
As Bud stated in one of his responses, the Alde system hot water heater build up some pressure when on all the time. additionally, for the system to function at its best there needs to be an air pocket in the tank. Over time this pocket goes away. The solution is to open the pressure valve about once a week and let all the water in the tank drain. Make sure that all incoming water is OFF. Open the drain valve under the dinette, drain water, close everything back up and turn water back on. No more leaking under trailer.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 08-07-2017, 04:50 AM   #5
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
When parked in one place for a while I have found that the once per month draining is not sufficient. I drain, when I think of it, about once every ten days. Simply turn off the campground water and drain the trailer. Turn water back on and that is it.
Bud
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) - 68-72
Old 08-07-2017, 09:24 PM   #6
Quilts&Brews
Thank you everyone ... I drained all tanks and that did the trick
Old 08-08-2017, 08:54 AM   #7
paiceman's Avatar
Great to hear - Enjoy.
Bud
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
being frugal with hot water ó best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 10:14 AM
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 02:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
Draining issue Siamese66 1970-79 Tradewind 11 11-08-2006 07:51 PM
