Took the camper out for the first time this season and I have a steady drip coming from the center of the picture and from the bottom of the white tray where the water hooks up. It's actually coming from the left side of the city water connection but then dripping everywhere. I looked inside under the sink and everything appeared to be dry. The leak is about a foot aft of the sink. Any ideas?
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
Also I just checked the water pump and under the sink and it all looks good. However if I look up to the left of the water connection it appears the wood is wet but I can't see well enough to be sure. I don't even know what connection goes in there.
2018 Classic 30
2012 F250 6.7l
I would check the hot water tank drain valve. It’s under the sink on the floor behind the removable panel.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
I have to correct myself. You have a 2018 Classic. So you have an Aldi system. It’s the relief valve drain on the hot water system. Pop it open and let it snap back down to reseat it. It could be that the water pressure is to high and the incoming regulator Is doing its job.
Thank you and I will try that. However doesn't that vent under the camper towards the front? This leak looks like it's under the bathroom sink and I cannot get to the bottom underneath the cabinet. However up top on the sink it is all dry.
2018 Classic 30
2012 F250 6.7l
