Old 05-15-2020, 02:42 PM   #1
2018 30' Classic
Williamsburg , VA
Help with leak
Took the camper out for the first time this season and I have a steady drip coming from the center of the picture and from the bottom of the white tray where the water hooks up. It's actually coming from the left side of the city water connection but then dripping everywhere. I looked inside under the sink and everything appeared to be dry. The leak is about a foot aft of the sink. Any ideas?Click image for larger version
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 05-15-2020, 03:05 PM   #2
2018 30' Classic
Williamsburg , VA
Also I just checked the water pump and under the sink and it all looks good. However if I look up to the left of the water connection it appears the wood is wet but I can't see well enough to be sure. I don't even know what connection goes in there.
2018 Classic 30
2012 F250 6.7l
Old 05-15-2020, 06:01 PM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I would check the hot water tank drain valve. Its under the sink on the floor behind the removable panel.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 05-16-2020, 05:44 AM   #4
2018 30' Classic
Williamsburg , VA
Thank you for the response. I cannot figure out how to remove the panel for the sink in the bathroom. I'm in a 30' Classic.
2018 Classic 30
2012 F250 6.7l
Old 05-16-2020, 05:53 AM   #5
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I have to correct myself. You have a 2018 Classic. So you have an Aldi system. It’s the relief valve drain on the hot water system. Pop it open and let it snap back down to reseat it. It could be that the water pressure is to high and the incoming regulator Is doing its job.
Also see here
https://www.airforums.com/forums/sho...34#post2360234
I chose America
Old 05-16-2020, 06:19 AM   #6
2018 30' Classic
Williamsburg , VA
Thank you and I will try that. However doesn't that vent under the camper towards the front? This leak looks like it's under the bathroom sink and I cannot get to the bottom underneath the cabinet. However up top on the sink it is all dry.
2018 Classic 30
2012 F250 6.7l
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 05:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
