RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-23-2020, 03:41 PM   #1
2019 33' Classic
townsend , Tennessee
Heated Towel Rack By-Pass
Anyone thought of or has completed a by-pass to the heated towel rack on the 33í Classics?
If we set the Alde thermostat control to use the bedroom thermostat, the back of the trailer gets rather warm. Typically we set the bedroom to 67 at night, yet on cool nights the living room stat will read 74.
Two parts to the problem, I believe. First, the bedroom is at the end of the glycol loop. Second, the towel rack is a lot of exposed hot tubing that heats up the bathroom.
It seems that if we by-passed the towel rack we could minimize heat loss in the glycol at the back of the trailer. Also with less surface are to exchange heat, the back of the trailer would not get so hot.
Thanks for any comments or suggestions.
By the way - the Alde hydronic heat is just awesome.
BryonJ is offline   Reply With Quote
Old 09-23-2020, 04:23 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
How about turning down your circ pump, allow the fluid more time to heat and circulate?
You could also temp the air next to the vents to check temp. You should only have a small variation between the front and the back. Our 30 is within a few degrees difference between front and back.
May also be able to set up a very small fan to increase air circulation from back towards the front?
If you wanted to bypass the towel bar, Iíd just save it as a last case scenario.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 09-24-2020, 08:22 AM   #3
2019 33' Classic
Good thoughts but the 33í is entirely different than the 30í this way. The exposed towel rack is a lot of surface area at the beginning of the loop. No matter what you do with thermostats, pump speed, etc, the glycol will lose a lot of heat into the bathroom.
I might try to speed up the pump; however, the towel rack is about 8í of exposed pipe, so I donít think it will have much Impact.
Perhaps as a trial I could insulate the pipe?
Old 09-24-2020, 09:16 AM   #4
2018 30' Classic
The 30 has the same towel bar.
Your alde system is under your dinette as is mine, are you sure your flow goes to the rear of the trailer first or does it flow the opposite direction? Iím not certain of that fact.
I believe mine goes in an anti clockwise flow but now that it is brought up, Iím not certain. In your case it matters as it changes the theory. If the towel bar is hot at the end of the loop then your challenge isnít with the towel bar but with something else.
BigSxyWhtGuy
Old 09-25-2020, 08:57 AM   #5
2019 33' Classic
You are correct, the Alde is under the dinette. The flow is from the dinette to the rear of the trailer, around the back up to the front then on the door side it loops back around to the dinette. It does not cross the door.
Slowing the pump will not help as it is not a glycol temperature issue, rather a heat transfer issue. The exposed pipe of the towel rack is just too much surface area. The glycol retains plenty of heat when it gets to the front bedroom, it has just "given" the bathroom a lot more than it needs.
That said, the system works great and I would never trade it for the traditional propane forced air heaters.
Like in all things RV - you have to find a balance. If I set the the Alde thermostat to "sofa" the back stays comfortable, but the bedroom gets a bit cool. I guess that's why Airstream provided a nice comforter for the beds😉
Old 09-25-2020, 01:26 PM   #6
2018 30' Classic
Cool, sounds like your mind is set on bypass or insulation. Good luck, let everyone know how it turns out and if it helps
BigSxyWhtGuy
Old 09-26-2020, 12:03 AM   #7
2019 - 33' Classic
RickyNelson's Avatar
2019 33' Classic
Grand Junction , Colorado
Following...
Thank you!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
RickyNelson is offline   Reply With Quote
Old 09-26-2020, 08:19 AM   #8
2019 33' Classic
Towel rack is at the beginning of the loop. Bedroom is at the end.
Old 09-26-2020, 08:22 AM   #9
2019 33' Classic
Just seems the most logical at this point. Iím not an engineer but did do a lot of work with heat transfer when forming and quenching hot metal. We learned that surface area and contact were more important than temperature and flow rates.
Will be camping in two weeks in the mountains of east TN. I expect temps below freezing, so it the insulation test will get a good tryout.
Adding a Towel rack to wall Uke player General Interior Topics 10 08-07-2020 03:52 PM
Bathroom Towel Rack - Relocating Frank&Mike 2006 - 2010 International 6 03-06-2013 09:34 AM
Adding towel racks and spice rack twestover Cabinets, Counter Tops & Furnishings 18 12-10-2009 11:26 AM
GoldenAge Pass aka America The Beautiful-The National Parks & Federal Rec Lands Pass Driver1 Boondocking 16 07-22-2009 11:00 AM
Towel rack inside shower? altamont Sinks, Showers & Toilets 1 02-27-2007 06:19 PM
