10-15-2020, 05:52 AM
2021 30RB Classic
Coconut Creek
Goofy stuff on the new 30’ Classic (2021)
I will have an in-depth review of my experience with the new Classic soon, but until then, an observation or two about some eyebrow raising items...
1. There are four wooden shelves that come with hardware (support pins) for mounting inside the shallow bathroom cabinet against the rear wall, just above the floor. In my case, the support pins were too long for the pre-drilled holes and did not fit properly, preventing installation of the shelves. 🤨
It was necessary to grind down the pins by about an eighth of an inch each (there are 16, four for each shelf) in order to get them to properly fit. See photos attached.
Current: 2021 Classic 30' RBT
Past: 2019 Flying Cloud 27' FBT
WBAC 9602
Instagram: Cirrusaly.Silver
10-15-2020, 06:31 AM
CLOUDSPLITTER "Tahawus"
Zanadude Nebula
, Milky Way
Are they paying you to do the PDI?
Definitely a dealer do. 'Here is a shelf option for this storage space, would you like us to install the hardware?
But then again....no would probably have been the correct answer.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
10-15-2020, 06:49 AM
2012 25' FB International
Trent Woods
, North Carolina
Why did you choose to grind the pins instead of drilling out the holes?
Larry
10-15-2020, 06:56 AM
2021 30RB Classic
Coconut Creek
Larry
Less work, in the end.
Drilling out the holes would necessitate more precision (lining up the bit in a very tight space, ensuring correct depth), and there are many more holes (as options to place the pins) then there are pins.
WBAC 9602
10-15-2020, 07:27 AM
Trent Woods
, North Carolina
Your call, but the hole depth does not matter because the pin can only insert so far. I would have put a piece of tape on the drill bit and had the job done in less than 5 minutes. Yes, the cleanup would have to be in the trailer instead of the shop but I agree with the least amount of work concept, anyhow.
Larry
10-15-2020, 10:59 AM
2020 30' Classic
Blue Ridge
, Georgia
2020 30' Classic. Had a problem with my pins kept falling out until someone on forum told me to put a little silicone in each hole. Bathroom cabinet shelves
10-15-2020, 02:23 PM
2018 33' Classic
Fresno
While you are at it, put a small piece of 2 sided tape on the front L and R brackets where they contact the shelf. The shelves will stay put during travel. Use some Amazon packing air bags to hold stuff in place when you close the cabinet door before travel and things won't fall off, out and into the sink, or floor in your case.
10-15-2020, 04:35 PM
High Desert Cat
2018 33' Classic
2021 19' Caravel
1999 35' Cutter Diesel Bus w/slide
Santa Fe
, New Mexico
Good call! I have the same year & model ( 2018 Classic 33 ), and the two additions made a huge difference!
If Kermit the Frog said it, I believe it's true!
10-15-2020, 04:36 PM
High Desert Cat
2018 33' Classic
2021 19' Caravel
Santa Fe
, New Mexico
Knife maker, have you had any other issues with your 33?
10-15-2020, 05:10 PM
2021 30RB Classic
Coconut Creek
Larry
Let me know if you have been successful in drilling those holes, especially the ones near the back of the cabinet. Very tight.
WBAC 9602
10-15-2020, 05:11 PM
2021 30RB Classic
Coconut Creek
Good call! Thanks!
WBAC 9602
10-15-2020, 06:47 PM
1995 30' Excella
1998 34' Cutter Bus (Chevy)
Goodyear
I am truly blown away! Spend $100,000 + on a 2021 A/S 30' and have to grind hardware or drill deeper hardware holes. "Come On Man" , has A/S truly lost it already medocare quality to a lower standard? In the past, they blamed the poor quality on the equipment they purchased from a vendor and outfitted it in an A/S.
10-16-2020, 06:33 AM
Riveted
2018 33' Classic
Charleston
, West Virginia
Akmoores, knifemaker
Might take a look at “Medicine cabinet organization” on the current Classic forum side. Dowel rods in the shelf slots along with the dab of silicone on the shelf supports work very well to keep things in place.
10-16-2020, 07:36 AM
2019 30' Classic
New Milford
, Pennsylvania
This kind of stuff goes on and on. The wiring is the worst. Remember folks, its a "Thor".
10-17-2020, 07:48 PM
2014 25' FB International
Somewhere
, Virginia
I will picking my new Classic up in January and would love to read your review. Thanks for your posting.
11-09-2020, 12:08 PM
2020 30' Classic
Richmond
, Virginia
I had the exact same problem. I took it in under warranty. Unfortunately I didn't think to make which shelves to use so I will probably have to do a workaround myself eventually (or take it back again)
12-21-2020, 03:47 AM
Clyde&Lorene
2021 33FB Classic
Morgan Hill
Our '21 Classic 33 did come with 2 medicine cabinet shelves, but no mounting hardware pegs. Found them at Home Depot-the larger pegs worked because our cabinet holes were big.
I like the dowel idea for keeping things in place during travel days.
01-09-2021, 10:33 AM
2020 30' Classic
Niantic
, Connecticut
On my 202 Classic, I also had to drill out the holes on the sides so the shelf brackets would fit. Since the brackets had holes, I purchased small screws and screwed each shelf bracket into the bottom of the shelves...they are going nowhere.
