Old 10-11-2020, 02:33 PM   #1
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Front Door Latch
Already posted in doors and locks section but no hits. Though maybe some here may have an answer?
Iíve got a 2018. Noticed the door latch doesnt pop back into place like it was doing before. Luckily door still opens.
I opened up the latch and saw a little spring had broken and itís just sitting on the ledge. Was hoping someone had a schematic that I could look at to order a replacement spring... or is this something like I need to replace the entire assembly to fix this?
Can post pictures in the morning if needed.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 10-11-2020, 03:47 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Get a good quality non sticky wax like lubricant
Grease attracts dirt and makes it worse.
Get some dry carbon lub, used for old car antenna, or we use boeshield t9
waninae39 is offline   Reply With Quote
Old 10-11-2020, 04:27 PM   #3
2018 30' Classic
Thanks, I assume thatís for after the spring is fixed. Any thoughts on replacing the spring? Is there a part number for it or so I need to replace them entire exterior assembly?
BigSxyWhtGuy
84 Sovereign Front door latch Logbear Doors & Locks 9 03-19-2017 04:21 PM
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
New finish on old front door latch Lexxy Doors & Locks 8 04-03-2014 02:37 PM
'78 Argosy Front Door Handle / Lock / Latch Markeyro Doors & Locks 8 08-19-2013 02:56 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
