04-28-2018, 07:54 AM
2015 28' Flying Cloud
2018 33' Classic
Cumming
, Georgia
Equalizer WD hitch
Just traded 2015 FC 28 for 2018 Classic 33. Have Pro Pride on the 2015 FC but will have to switch to a conventional WD hitch. Dealer recommending Equalizer. TV is 2015 Chevy HD 2500, Duramax. Is the Equalizer a good choice for my total package?
04-28-2018, 08:03 AM
ObviouslyKnot
KAILUA
, HI
I love my pro pride on the 17 classic with my RAM. Why ditch the pro pride?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
04-28-2018, 08:05 AM
2016 25' Flying Cloud
Venice
I'm no expert on hitches but I've used the Equalizer WD hitch on various trailers, one being a 36' pulled by a F-250 and it worked great. I currently use it on my 25' Airstream.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
2018 33' Classic
Cumming
, Georgia
The new classic has its primary storage bin in front of trailer. The ProPride towers block access to this storage compartment
04-28-2018, 08:08 AM
ObviouslyKnot
KAILUA
, HI
Seems Sean at PPP had some new ratchet strap devices for the bars. Might be a solution?
04-28-2018, 08:13 AM
Tampa
Yes.
04-28-2018, 08:34 AM
2002 30' Classic S/O
Fleming Island
I towed my Safari 25 and my Classic 30 Slideout (9100#) with Equalizers. I used a 10,000# version on the Safari because that's what came with it when I bought it and traded for a 12,000# unit for the Classic on Equalizer's recommendation. I never had any incidences of sway or significant pushing from passing traffic in either case. I now have a ProPride mostly because it is easier to handle and store when not towing. I also feel it would be more predictable in an emergency maneuver but that remains to be seen given the "Hensley Bump".
Al
04-28-2018, 05:03 PM
2012 28' International
Olympia
Keep the ProPride
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
04-29-2018, 04:49 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Yes to the Equalizer question. I have used one on two different 30' AS including our 2017 Classic and tow with an F350 Diesel.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
04-29-2018, 01:01 PM
Reads a lot
Titusville
Never gave it much thought but getting to that storage area is gonna be a bear no matter what hitch because the lp tanks are in the way as well.
Lauri
She Believed She Could so She Did.
04-29-2018, 08:00 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Do NOT get rid of the PPP hitch, there is an effective solution, call and get the information.👍
POI....'hensley bump'...is not caused by a PPP hitch.
We've used one on two different TV's for 12yrs, correct set-up=no bump
04-30-2018, 05:51 AM
Green Cove Springs
Originally Posted by ROBERT CROSS
Do NOT get rid of the PPP hitch, there is an effective solution, call and get the information.[emoji106]
[emoji1148]
Ditto...keep the ProPride and call Sean for the solution to your issue. You’ll be glad you did.
Breathe In, Breathe Out, Move On
04-30-2018, 08:53 PM
2018 30' Classic
Jacksonville
I use a Blue Ox. The cams don't interfere with anything above the frame. We did have to put a shorter bolt in the "Set Screw" position. The long ones conflicted with the battery box.
http://www.blueox.com/trailer-towing/swaypro/
Pulled the last trailer with one of these too. Weight was not a problem but it keeps it from swaying. Without it swaying occurred. Doesn't need that friction bar either. An added benefit is the insert/hitch projects a little over a foot past the bumper making it easy to lower the tail gate when the trailer is hooked up.
04-30-2018, 10:17 PM
TinCan
2016 30' Classic
Apache Junction
I have no issues with my Equalizer pulling a 30' Classic. Having F250 helps also.
TinCan
