Old 06-14-2020, 05:58 AM   #1
2020 30' Classic
Norman , Oklahoma
Dometic refrigerator
We have a 2020 Classic 30 with a Dometic refrigerator (standard from factory). Recently the fan has been running constantly (day and night) and the noise it makes is annoying, to say the least!
Any of you experiencing this?
twinkie2 is offline   Reply With Quote
Old 06-14-2020, 06:06 AM   #2
2020 30' Classic
DALLAS , Texas
I have a 2020 Classic and it does the same thing until I cool the trailer down. Must be a cooling fan,
Phantom98 is offline   Reply With Quote
Old 06-14-2020, 06:22 AM   #3
2020 30' Classic
DALLAS , Texas
Don't call Dometic. They don't have a clue.
Old 06-14-2020, 08:52 AM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
My dometic fridge does not have a fan. Are you sure itís not the fan on the converter, in the power center, located below the fridge?
Those are known to run when the cabin is warm or if you are pulling a lot of 12v loads.
wulfraat is offline   Reply With Quote
Old 06-14-2020, 10:33 AM   #5
2020 30' Classic
DALLAS , Texas
The only thing below the fridge on the Classic 30 is the water pump. I'm pretty sure it is a cooling fan.
Old 06-14-2020, 10:45 AM   #6
Cirrusaly's Avatar
2021 30RB Classic
Coconut Creek , Florida
The 2020 manual references a Power Ventilator for the refrigerator. When I searched the part number - 690394 - HighSkyRVParts.com returned an "Airstream OEM" part, which appears to be a standard 12V "computer" style fan. It comes with a sensor.
I'm not sure where it's installed on the 2020 30' Classic, but the parts website says it will run when the refrigerator is on and the temperature is hot. Duh.
Maybe the sensor is bad? Again, I'm not sure where it's located, but I'd guess at either the top of the refrigerator compartment (under the roof vent), or just at the bottom of the coil. If the latter, then it might be visible from the outside refrigerator access panel.
Current: 2021 Classic 30' RBT
Past: 2019 Flying Cloud 27' FBT
WBAC 9602
Instagram: Cirrusaly.Silver
Cirrusaly is offline   Reply With Quote
Old 06-14-2020, 10:57 AM   #7
2020 30' Classic
DALLAS , Texas
I didn't know a computer fan could be that noisy. After a while it sounds like a fog horn. LOL When I get back from a trip the fan is on for a while until the trailer cools down. I store my Airstream in a climate controlled building. While camping I run the AC so they keep it cool so when I'm in it the fan doesn't run
Old 06-14-2020, 11:08 AM   #8
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I had some fans get dusty and growl a-lot. Sometimes a few good blasts with a compressed air can cold clean them up. If the bearings packed it in, I would have to replace the fan.
Another thing to consider is if the fan is touching part of the trailer without being properly isolated, then the vibrations will travel into the trailer and be amplified by the aluminum.
It must be in a place where dust can build up quickly.
Perhaps checking for proper isolation and a blast of compressed air will help.
I recently bought a back up hard drive case and comes with a whisper quiet fan but even that adds 20 dB's to the work area.
PB_NB is offline   Reply With Quote
Domestic refrigerator problems Dadams 2016 - Current International 6 07-24-2019 01:51 PM
Help! Domestic refrigerator not cooling. NWRVR Refrigerators 15 09-18-2016 11:07 PM
domestic fridge problem nightowlhooter1 Refrigerators 7 05-11-2016 10:25 AM
Domestic Shipping Recommendations? BeBop Shipping & Export/Import 1 12-10-2005 06:29 PM
