Old 03-10-2021, 10:58 AM   #1
2016 30' Classic
Houston , Texas
Dometic CU434 stove/oven - How to access thermocouple
I have the Dometic CU434 stove/oven in my 2016 Classic. The larger front burner lights-up well with a strong flame. However, when I release the knob, the flame goes out. FYI, the other two burners work well.
I think the burner's thermocouple is not working well. I cleaned the end near the burner with steel wool although it was not visibly dirty. Post cleaning, the flame still went out when the knob was released.
I want to get under the stove surface to better inspect the thermocouple. Having trouble determining how to lift the stove surface.
Any ideas? Thanks
dhroberts is offline   Reply With Quote
Old 03-10-2021, 07:37 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
I believe you have the same one we have in our 2018. Only way to access everything is through the back which means uninstalling it from what I understand.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 02-03-2023, 12:31 PM   #3
scotomaville's Avatar
2021 30' Globetrotter
Mosier , Oregon
Any ideas? Thanks
I have the same issue. How did you solve the replacement?
scotomaville is offline   Reply With Quote
Old 02-04-2023, 07:08 PM   #4
Mosier , Oregon
The Spokane Airstream service advisor tells us that they can extract enough of the thermocouple to re-solder a replacement, and that it's doesn't require a complete oven/cook-top warrantee replacement.
Elsewhere I read that getting the cooked bits out of the cook-top cooling vent isn't possible without removing the over, and drilling out the rivets. I forced q-tips through the grill slots and dabbed up all the bits. An hours attention, but much less than removing the entire unit.
"the greatest expedition you will ever undertake is the journey to self-understanding"
Daniel Comp
https://scotomaville.com
Daniel Comp is offline   Reply With Quote
Dometic CU434 Stainless Oven Range 4riveteers General Appliance Topics 27 07-22-2022 08:41 PM
The new Dometic SMEV CU434 stove/oven operation switz 2016 - Current Classic (all lengths) 10 06-12-2019 08:18 AM
Dometic Thermocouple drcamo Refrigerators 5 02-16-2012 11:39 AM
Thermocouple for Royal Dometic? MATTY J Refrigerators 12 01-31-2012 07:06 PM
Thermocouple for '68 Safari Dometic refer 26.982 amu Refrigerators 3 02-16-2009 08:29 AM
