Old 09-26-2021, 02:14 PM   #1
2021 33FB Classic
Box Elder , South Dakota
Disable CZone Warning Message
Does anyone know if there is a way to disable individual warning messages from appearing on the CZone panel or at least prevent them from waking the display when it is off? We have 2021 Classic 33. Before going to bed we like to turn the display off by either tapping on the sleep mode button or manually turning off just the Czone display. Recently the cooler night temperatures started causing the tire air pressures to drop, triggering repeated low tire pressure warning messages on the display. Each message wakes the display, turning on a very bright screen in the middle of a very dark trailer. I tried changing the settings on the TST TPMS module but that didnít seem to have an impact on the CZone warnings.
andyairstream is offline   Reply With Quote
Old 09-26-2021, 03:22 PM   #2
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
Are you in Sleep Mode? When we put our Ď21 Classic 33 in Sleep Mode and turn the display off - the alarms do not wake up the display.
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Old 09-26-2021, 06:19 PM   #3
2020 33' Classic
DFW , Texas
X2 Annabelle33. We also put the czone cover on at night.
no_worries is offline   Reply With Quote
Old 09-26-2021, 06:45 PM   #4
2021 30RB Classic
Tucson , Arizona
Smile
That happened to us too. After considering how hard it is to pull the trailer into the gas station for air, ended up buying a portable compressor for pumping up the tires. Much more convenient now for airing up the truck and the airstream. Best thing is—no more alarms.
Arthur
turonueve is online now   Reply With Quote
Old 09-27-2021, 03:51 PM   #5
TKCamper's Avatar
2018 30' Flying Cloud
2020 30' Classic
Hubbard , Oregon
The owners manual for the Classic will tell you how to adjust the warnings on the TPMS system. It is pretty easy, you will need to have the TPMS monitor with you and locate the repeater. In our Classic 30 it was near the c-zone fuse box under the closet.
TKCamper is offline   Reply With Quote
Old 10-04-2021, 05:17 PM   #6
2021 33FB Classic
Thanks everyone the the advice. I followed the directions in the manual to sync the external TPMS module to the module in the Airstream and the warnings went away. I didnít put two and two together that step was needed - I thought it was only needed if you rotated the tires. Lesson learned!
Permanently disable door lock truckasaurus Doors & Locks 5 08-06-2012 10:40 AM
How to disable brakes due to pin pull on breakaway switch Butcher Brakes & Brake Controllers 3 06-20-2010 08:29 PM
How do I disable automatic notification kamadeca Forum Admin, News and Member Account Info 3 02-02-2009 08:41 AM
How to disable contentlinks Janet H Our Community 4 05-13-2007 11:21 PM
