11-13-2020, 10:41 AM
2021 33FB Classic
FRISCO
, TX
Dexter Lift Not Available - 2021 Classic 33FB
Just got off the phone with Dexter who reported to me that they do not make or recommend a lift for the axels on my new Classic. They sent me the build sheet for my axels (via serial number) that indicates it has “Top Shock 149” brackets. She told me that she had an internal memo that stated lift kits would not be possible with that bracket configuration.
Anyone else encounter this or have a solution? I am convinced that it is likely impossible to tow this coach without dragging and already need to replace one of my drag plates.
Thanks!
Dave Massey
2021 Classic 33FBQ; 2020 F250 Lariat 7.3 Godzilla
11-14-2020, 06:30 AM
Riveted
2018 33' Classic
Charleston
, West Virginia
Not sure what is different on the 2021. I know others on the forum have installed the lift kit and I have seen it installed on a 33 at JC this past spring. Curious as to why Dexter said no. On a side note I have been trying for the past month to get an answer from Dexter about taking weight off the axles for winter storage. I have not been able to talk to anyone in tech Dept and they do not respond to emails. At one point the lady who answered the phone said lifting the trailer to remove weight off the axles would not make a difference on torsion cord life. Very disappointed with Dexter.
11-14-2020, 07:29 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I’ve lifted 3 2021 trailers none of which were a Classic though. I did lift a 2020 Classic yesterday and it was the same as any other airstream I’ve done.
11-14-2020, 01:51 PM
2018 30' Classic
Thousand Oaks
Ready for you to lift mine in January too! I’m an 18 though.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
11-15-2020, 06:48 PM
2020 33' Classic
DFW
The dealer installed the lift kit on our 2020 Classic 33FB. Sounds like Dexter changed the axle design.
12-23-2020, 01:32 PM
2021 33FB Classic
Cumming
, Georgia
Dave - did you end up getting this done? I was just quoted $1,500 for both axles from AS of Tampa. I am getting a 2021 Classic 33 FBQ too.
Thanks!
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
12-24-2020, 05:50 AM
2021 33FB Classic
FRISCO
, TX
AnnaBelle33,
Thanks for the note. I have not yet found anyone that can do it. My dealer here in Dallas/Ft Worth initially said they could and quoted $1,300 but later backed out when they could not order a lift kit from Dexter. Please keep us updated with your outcome...might have to drive to Tampa!
Dave Massey
12-24-2020, 06:04 AM
2021 33FB Classic
Cumming
, Georgia
Thanks for the reply. Merry Christmas!!
When did you last speak to AS DFW? I called them yesterday to get a comparable quote to use as negotiation in Tampa. The service manager told me $1,000 and it would take a half day. I emphasized it was a 2021 Classic 33 three times and he said no problem.
He did say I needed to send him the numbers off the axle so they could order the parts but acted like that was no big deal.
I pick up my AS this Sat, I’ll keep you posted. Thanks.
2021 Classic 33 FB
WBCCI# 8026
02-11-2021, 09:54 AM
2021 33FB Classic
FRISCO
, TX
AnnaBelle33,
Did you get your lift? I am still out of luck due to there being no compatible kit from Dexter to go on the axels I have (based on their serial numbers).
Dave
Dave Massey
02-11-2021, 04:22 PM
2021 33FB Classic
Cumming
, Georgia
I’m on Ronnie’s (GMFL / Airstream Nuts & Bolts) April schedule. eTrailer says there is a 2” lift but I’m going to have him do a 3”. I’m hoping there is a Dexter 3” in the next three mos, if not - I’ll let him work his magic with his 3”.
2021 Classic 33 FB
WBCCI# 8026
02-15-2021, 06:34 AM
2021 33FB Classic
Cumming
, Georgia
Dave - an update.
I sent my serial number to Dexter and they sent me back this:
2021 Classic 33 FB
WBCCI# 8026
02-20-2021, 04:14 PM
2021 33FB Classic
FRISCO
, TX
Originally Posted by AnnaBelle33
Dave - an update.
Thanks! I sent another email to them asking if anything had changed and they sent that to me as well. While my hopes are up and I have ordered that kit from E-Trailer, the text on their site warned it would not work with axels that have top mounted brackets... fingers crossed!
Dave
Dave Massey
02-20-2021, 05:35 PM
2021 33FB Classic
Cumming
, Georgia
Keep me posted with your success. Good luck!!!
2021 Classic 33 FB
WBCCI# 8026
02-21-2021, 01:34 PM
2013 31' Classic
billings
, Montana
Thanks!
Maybe you could post pictures....as the shock mounts can be moved...
03-01-2021, 05:35 AM
2021 33FB Classic
FRISCO
, TX
All...
The kit Dexter suggested for my #11 axels is now installed. It took 9 hours but mainly because I’m not as young and spry as I used to be. Additionally, if I could weld, I would have put tabs on 8 of the screws as getting a wrench on them was next to impossible. That would have cut about 3 hours off the timeline. Dexter should offer a “tabbed” option. A nice impact wrench would have helped as well...for some of the bolts. A few are right behind a wheel drum and don’t have clear access. While I saved ~$1,200, I spent $400 on the proper jack and jack stands. (If your in The Dallas area and want these, let me know.). Thankfully, I already had the other tools, including a heavy duty torque wrench.
Dave Massey
03-01-2021, 05:39 AM
2021 33FB Classic
Cumming
, Georgia
Thanks Dave. Congrats!! Do you have a before & after pic? Is it 3”s or 2 3/4”?
2021 Classic 33 FB
WBCCI# 8026
03-01-2021, 10:26 AM
2021 33FB Classic
FRISCO
, TX
Unfortunately, I forgot to take pics! However, prior to the install, the tops of the tires were recessed into the tire well and were not visible when standing to to the side of the trailer. Now, you can see the tops of the tires. The lift blocks were exactly 2 7/8ths tall (so almost three inches).
Dave Massey
