07-30-2022, 02:34 PM
2021 30RB Classic
Saint Augustine
CZone Panel not reporting tire pressures
2021 Classic 30
After swapping some tires around (moved spare tire from its rim to one of the aluminum rims, and that tire to the steel rim to use as spare), I also “rotated” the right side tires. Once all the tires were back in place, I used the TST monitor to relearn all five sensors. The TST monitor reports all five tire pressures and temps correctly. I then followed the instructions in the Classic manual to update the CZone using the TST gateway. All beeps and lights confirmed successful update. And yet, this on my iPhone… (see first picture). The CZone panel is depicted in the second photo. I’m unsure why the spare is accurately reporting and the other four are not.
I drove today about 30 miles on the tires, hoping that the motion would update everything. Still nothing.
Current: 2021 Classic 30' RBT
Past: 2019 Flying Cloud 27' FBT
WBAC 9602
Instagram: Cirrusaly.Silver
08-02-2022, 06:40 PM
2019 30' Classic
Rome
, Georgia
Not directly related to your issue but I’ve had two issues with my cZone which were resolved with a reboot. One was related to the panel not responding to touch on the tank gage. The other was related to the front air not restarting after cycling off when the desired temp was reached.
I did a battery disconnect on the panel button pushed the button to reconnect. The cZone restarted loading the configuration. This solved both issues.
You might consider seeing if this would resolve your issues.
08-05-2022, 01:21 PM
2021 30RB Classic
Saint Augustine
Thanks, BLPeace1. Went through several complete "resets," with no luck. Still searching for a solution here...
WBAC 9602
01-19-2024, 06:17 PM
2024 30' Classic
Boise
, Idaho
It's been a while, have you figured this out? When I go to access the gateway under the closet (black box with antenna and clear button in the middle), it is not lit up and does not respond to pressing it at all (eg 5 presses and it should beep - it does nothing). So I can't even write back to CZone on the tires currently. Is there something that "powers" up the TPMS gateway that I'm not doing?
01-30-2024, 03:39 PM
2021 30RB Classic
Spearfish
, South Dakota
similar issue. had a tire replaced and they damaged the transponder. replaced the unit with new and now i get no reading on c-zone. it registers on my TPM unit inside the truck. how do you get the c-zone to recognize the new transponder?
01-30-2024, 07:19 PM
2023 33' Classic
Manassas
, Virginia
There is a re-learn procedure that needs to be done. It is accomplished by placing the TPMS repeater (it’s hidden inside your trailer…on my 33 it’s behind a removable panel under the desk) into ‘learn mode’. You need to bring your TPMS inside the trailer with you and what you’re doing is getting the CZone programmed with whatever is in the TPMS. I’ve done the procedure a couple of times to change the tire pressure limits so I wouldn’t keep getting low tire pressure warnings on cold nights.
JC sent me the procedure and I think the procedure may also be in your owners manual (Airstream owners manual). If not, reach out and I can send it to you. The procedure is fairly straight forward, but even so I had to do it a couple of times to get it to “take” the changes.
02-23-2024, 05:12 PM
Freedom
2023 30' Classic
Dallas
, TX
Updating TPMS Monitor and CZone©
Any time you physically move a tire to a different
position, such as changing or rotating tires, you will
also need to update the sensor configuration on the
TPMS monitor and update the link between the monitor
and CZone.
A manual for the TPMS monitor has been provided with
your owner’s packet. Their manual contains warnings,
cautions, and information on updating the sensors that
should be reviewed.
Updating TPMS to CZone© Link
• Locate the TST Gateway transmitter wired to
CZone backbone. In the 30’ Classic, it is located
in compartment below wardrobe closet. In the 33’
Classic, it is located by removing drawer below the
convection oven.
• On the TPMS monitoring display, press and hold the
“Go” button for approximately 3 seconds until the
screen displays “ACC EPT”.
• Press the “+” button 5 times until “SEnd” is displayed.
• Place the TPMS display close to the Gateway
transmitter. Press the button on the transmitter (this
is the button that is actually a red blinking light) 5
times rapidly. The transmitter will then “beep.”
• Press and hold the “Set” button on the TPMS monitor
until both, the transmitter and monitor, beep and the
display shows “ACCEPT.”
2023 30 Foot Classic
2022 Ram 3500 Dually
02-23-2024, 05:33 PM
2023 33' Classic
Casa Grande
I received the lastest from Airstream and the only difference to KCurtis instruction is:
5. Place the TST display close to the Gateway and press “Set” button once quickly per Figure 6.
Steven & Lisa
"Mandy" 2023 Airstream Classic 33
2016 Dodge Ram Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
WBCCI Region 11 President - Life Members #222, AIR #118556, KJ6DKF
02-23-2024, 05:51 PM
Freedom
2023 30' Classic
Dallas
, TX
Thanks for the update. I just looked at the 2024 Manual and it still hasn't been updated.
