Old 06-06-2021, 02:46 PM   #1
2020 33' Classic
Heart Of , Texas
CZONE panel Frozen
Bought our 33 Classic used a few weeks ago. Camped at the dealer in Tampa, Florida and a second night In Biloxi, MS. Czone worked fine until we parked in our storage lot in NE Austin, TX.
Panel lights up but will not take touch commands.
Read a few threads here about turning off main (RED) power switch under our dinette for 10 min. Attempted twice no luck.
Checked under the couch and all connections seem correct
Keith & Barbara
2020 Classic 33 FTB
2019 Ford F250
Blue Ox Hitch
KBAR is offline   Reply With Quote
Old 06-07-2021, 10:34 AM   #2
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
I'm in the middle of dealing with Cory up in Jackson with my own CZone issues. One of the things you could try that he had me do was - pull the panel off the wall and unplug the three wires (power, ethernet and wires going to COI and Contact 6). Wait 60 seconds and then plus them back in. That will do a reset.
No idea if this will help you but that was the first thing he had my try with my 2021 Classic 33 CZone issues. You mentioned you got yours used so I dont know the year or if our panels are even the same.
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Old 06-07-2021, 02:59 PM   #3
2020 33' Classic
Heart Of , Texas
Originally Posted by AnnaBelle33 View Post
pull the panel off the wall and unplug the three wires (power, ethernet and wires going to COI and Contact 6). Wait 60 seconds and then plus them back in. That will do a reset..
Did that exact method this morning. Talked to the RV dealer where we bought the AS in Tampa, Fl. They suggested to disconnect the negative posts at the batteries ( did not effect the frozen panel was still on) Turned off the power switch under the dinette (panel still on) Got to thinking about the PDI and how they revealed the panel in the bath to service the glycol. Just behind the glycol reservoir is the Zone panel. Did not see and fasteners that would hold the Czone panel. So I took the chance and pulled the Czone panel and in came out (it is held in place with a good deal of force). With all the other disconnects I removed the three connections, (Czone white command wire, cat6, and green power block) Waited a few minutes then reversed connecting everything.
Power panel came on rebooted (a minute or so) and the panel was fully functional. I really don't want to replace this panel. I've seen cost ranging between $1,100 - 1,300.
Keith & Barbara
2020 Classic 33 FTB
2019 Ford F250
Blue Ox Hitch
Old 06-09-2021, 02:51 PM   #4
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Should be warranted.
DeltaRon is offline   Reply With Quote
Old 06-10-2021, 12:33 PM   #5
dmassey321's Avatar
2021 33FB Classic
FRISCO , TX
My Czone panel froze this AM as well. It was stuck on the white Airstream logo screen. Tried everything to disconnect power so that it might reset to no avail. Then saw the post above. Reached into the cabinet between the panel and the shower (by the Glycol reservoir) and unplugged the three wires. Waited about a minute and then plugged them back in. After about 30 seconds, the white screen went away, and hour glass popped up for a short time and then everything was back to normal.
Dave Massey
2021 Classic 33FBQ; 2020 F250 Lariat 7.3 Godzilla
dmassey321 is offline   Reply With Quote
Old 06-10-2021, 03:24 PM   #6
2021 33FB Classic
Cumming , Georgia
Awesome.
Im still fighting my CZone ghost. Ive tried everything - checked and rechecked every connection. Probably a bad COI or Contact 6 box. Gotta love technology.
2021 Classic 33 FB
WBCCI# 8026
Old 06-10-2021, 10:54 PM   #7
2020 33' Classic
Heart Of , Texas
Happy that someone else benefitted from the Czone mystery.
AnnaBelle33 I hope you make it to the goal line with your ghost.
Keith & Barbara
2020 Classic 33 FTB
2019 Ford F250
Blue Ox Hitch
CZONE Display Reset? PaulR-GA 2016 - Current Classic (all lengths) 18 08-06-2020 08:10 AM
CZone panel issues Roadtoaster Electronics & Connectivity 0 07-23-2019 06:08 AM
CZone and Multiplex Interfaces In General Re-Pete 2016 - Current Classic (all lengths) 10 05-26-2019 09:11 AM
Regarding Multiplex Interface Systems such as CZone, etc. Re-Pete Electronics & Connectivity 0 04-16-2019 10:53 PM
CZone app skiphoyt Sprinter and B-van Forum 1 03-07-2019 07:42 PM
