Old 04-24-2024, 04:25 PM   #1
2021 30RB Classic
Waynesville , North Carolina
CZone Contact 6-01 switch module offline
Our 2021 Classic RBQ has yet another CZone issue. Whee! What fun.
One switch module is offline: Contact 6-01 (the 24 hour network: The fantastic fan and cover, sofa reading lights, and a few other circuits are controlled by this. If you are curious, it is behind the speaker panel in the shelf unit above the sofa, starboard/curbside.) It's an interesting problem. I cannot open the vent cover or start the fan from the display. BUT, if I crank the cover open manually then I can start and stop the fan from the display. I think there is a dependency; the display/controller probably cannot start the fan if the cover is not open. I know if you just press the fan speed, it automatically opens the cover. Also, the sofa reading lights won't work. Curiously, I was able to turn off the Battery Switch; did not try the inverter but we never use it anyway.
The network status LED on the Contact 6 module is green, and when you power cycle the module, all 6 LEDs flash green on and off. I think this means a successful self test. I have checked the address of the switch module and it is correct. But the module still shows offline on the Display/controller. I have disconnected and reconnected at Contact 6-01 and at the Display. I have also completely removed all power to cold-boot the system. No luck so far.
Is the display only a display or is it also the controller where the program is stored?
I've opened a ticket with Airstream but wanted to check here as well. I'm not holding my breath for Airstream. We are getting the African Queen ready for the Trot to Tryon this weekend. This won't stop us but would love to get it working.
DaveWarde is offline   Reply With Quote
CZone COI module location? Bean_Can Pottery Barn Edition 4 10-31-2023 01:17 PM
AC question- front are dropping offline BLPeace1 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-28-2022 05:36 AM
Taking differences offline Denis4x4 Off Topic Forum 1 03-01-2009 10:39 AM
Airstream Forums Offline...... leefields Forum Admin, News and Member Account Info 2 02-26-2006 06:43 PM
