10-18-2017, 01:50 PM
1972 31' Excella 500
Grapeview
Cook Top Exhaust noise.
The cook top Exhaust Fan (when on) in our 2017 Classic is comparable to my Stihl chain saw w/o hearing protection, may be not quit but close. Have not taken DB reading yet. I am doing research on replacing the fan unit or the exhaust unit altogether. Are there others that have looked into this and/or replaced. If replaced what did you replace with? Fan only or complete unit? Any help would be greatly appreciated.
Safe and happy travels.
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
10-18-2017, 01:58 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Have you unfastened the tabs on the outside that hold the exhaust flap closed while driving? If fastened closed it makes quite a racket.
Ray B.
10-18-2017, 02:07 PM
2015 30' Classic
Pleasanton
Some folks have had success with adding a resistor in series with the motor. Search "fan hood resistor". A general RV forum suggested this fix.
I haven't done this mod, but I can see that it wouldn't be very difficult to add a resistor to always slow down the fan, or add a resistor and switch to give you to option of two speeds. Most folks seem to target 5 to 10 ohms. The resistors should probably be sized at 20 W.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
10-18-2017, 02:21 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I believe you will find that it's a high back pressure blower rather than a fan. It's not going to be easy to find a simple replacement.
10-18-2017, 02:53 PM
2014 25' Flying Cloud
Cuddebackville
, New York
My 2014 is much quite than my 2007 was. In the '07 I installed the aforementioned resistor, which helped a lot. The '14 is loud, but tolerable.
2019 Ford Expedition Platinum
10-18-2017, 03:30 PM
Oswego
I installed one of these a couple years ago for the old style hood:
http://www.rvvent.com/fabulousoperatingproducts.htm
Super quiet, nice LED lights and draws a LOT more air. Not sure they make one for the Baraldi, might be worth a call. I used to think I wanted a Baraldi....not anymore!
-Rich-
10-18-2017, 03:53 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Our Hi-Tec exhaust noise suppression up-grade. When it gets lost in the slipstream, it's a very quick replacement.
10-19-2017, 10:10 AM
Grapeview
Looks to be what I am looking for. Can be bought on Amazon. However I have yet to find true dimensions of the unit. Being you have installed one, could you supply true dimensions. Greatly appreciated.
To the rest of you that provided feed back. Thank you. Yes the exterior vent clips were opened. I like the "hi-tech" clothes pen set up.
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
10-19-2017, 10:12 AM
Oswego
Which hood do you have?
-Rich-
10-19-2017, 10:20 AM
Grapeview
Baraldi
Model Swing
Cat.# 16116 02 10A
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
10-19-2017, 11:30 AM
Oswego
I would suggest calling them. I have the older square hood. I have no idea if these fit a beraldi
-Rich-
10-26-2017, 11:11 AM
Grapeview
Yes the SAM-1 will fit my 2017 Classic Baraldi hood. Thank you for the info and direction for the SAM-1.
Best regards and safe travels.
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
10-26-2017, 11:12 AM
Oswego
Great, I am very happy with the performance and noise level of mine.
-Rich-
