Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 11-10-2020, 02:43 PM   #1
2019 30' Classic
Norcross , Georgia
Converter/charger Info
Can someone tell me where I can locate the converter/charger and the model that was used on a ‘19 30 Classic?
I’m not having any luck on my own or with the document/manuals Airstream provided me.
Thank you!
PaulR-GA is offline   Reply With Quote
Old 11-10-2020, 03:03 PM   #2
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
WFCO WF-9855 converter
I found one in the classifieds thats out of the same year trailer as yours.
https://www.airstreamclassifieds.com...arolina-360239
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky #28279
2018 FC27FBQ
2021 RAM 2500 Hemi 6.4
KD3OBX 146.520
cptdzl is offline   Reply With Quote
Old 11-10-2020, 04:21 PM   #3
Cirrusaly's Avatar
2021 30RB Classic
Saint Augustine , Florida
The converter/charger is mounted to the floor, behind the circuit breaker panel. The breaker panel is easy to remove - 4 Phillips head screws. The breaker panel is behind the left floor level wood panel under the wardrobe.
Current: 2021 Classic 30' RBT
Past: 2019 Flying Cloud 27' FBT
WBAC 9602
Instagram: Cirrusaly.Silver
Cirrusaly is offline   Reply With Quote
Old 11-10-2020, 09:49 PM   #4
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
What about taking the time to upgrade to a better model? The stock one works but if you need to replace it, you may want to upgrade to a beefier system that would be better with a solar system. Just my .02
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 11-11-2020, 05:00 AM   #5
2019 30' Classic
Norcross , Georgia
You're spot on. That's exactly what I want to do and am hoping it's a simple DIY project to swap the stock converter and 2 AGM batteries with a lithium-able converter and 2 lithiums. Not looking to have to redo any wiring, etc.
Thanks everyone!
Old 11-11-2020, 05:39 AM   #6
2018 25' International
Slidell , Louisiana
You will have to watch the wire gauge and fuse sizes for the converter and battery leads if the new converter has higher charge capacity as they generally will for Lithium ready converters. Don't just upsize the fuses, they are there to protect the cables. If the fuses are too small, in all likelihood the cables are also.
Good luck.
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
It's official - no converter or charger & I need advice henrydahm Electrical - Systems, Generators, Batteries & Solar 11 07-31-2006 07:31 PM
Converter/charger humming in stereo blickcd Electrical - Systems, Generators, Batteries & Solar 6 01-05-2005 07:50 PM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
