Old 04-03-2020, 04:15 PM   #1
2019 30' Classic
Charlotte , North Carolina
Convert wardrobe into pantry
Almost done with converting our wardrobe into pantry drawers and converting the pantry from pull out to shelves. Much better space utilization. Also coating all overhead panels with lacquer. Harder and less prone to scratching, water borne.
1st 4 pics are sideways and you know...
1. Is everything closed up
2. is the right side open. It is about 12 in wide and has shelves. Allows access to the safe. 120 degree hinge with a bumper on the shower bump out. Will be moving the second light to this area from above.
3 is the full extension drawers all open. Everything is cork lined for anti slip
4 is the overhead area.
5 is the redone old pantry. Removed the pull out wire shelves and added shelves. Tons more space.
6 is one of the side tables next to the sofa
7 is the other side table. Side tables are not done yet.
Will coat all the remaining panels in the camper so the finish is the same glossiness.
Weight? Adds 200 lbs net. I donít think we will add more stuff, just wonít have it stacked in boxes, bags in the wardrobe. All shelves are Baltic birch with solid edges. Door/ drawer fronts are maple. Stainless flip up hinges for the side tables with a piece of alum sistered to the interior skin for strength. Rivnuts and a few rivets.
Also figured out how to lock the propane tanks. On the 2019, no room for a lock if you still thru the alum Ďwing nutí and tank cover brace unless you turn the nut upside down! Will post a pic unless everyone else already figured that out.
ID:	364743   Click image for larger version
ID:	364745   Click image for larger version
ID:	364747   Click image for larger version
LilPeanut is offline   Reply With Quote
Old 04-03-2020, 05:54 PM   #2
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
I love it. Well done
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 04-03-2020, 07:27 PM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Those shelves with the couch are a game changer!
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-04-2020, 05:30 AM   #4
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
Nice! What stain did you use to match so well?
JDG is online now   Reply With Quote
Old 04-04-2020, 08:45 AM   #5
2019 30' Classic
JDG - the stain was custom. The wood was different so matching was trial and error.
Old 04-04-2020, 09:34 AM   #6
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Very nice workmanship! Made a Classic even more Classic!
Mikebrady62 is offline   Reply With Quote
Old 04-04-2020, 10:32 AM   #7
The Panhandle , Idaho
Beautiful work. You are a true craftsman. If we lived closer I'd ask you to do the same to our Classic 30.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
Hoagie is offline   Reply With Quote
Old 04-04-2020, 11:12 AM   #8
2019 30' Classic
Most of the real work was done by a local guy I know. My storage place is closed so I kept it at his house since Feb 1 next to his shop. I did a few things but all the good craftsmanship is his while I was working from home.
Old 04-05-2020, 06:37 AM   #9
JDG
Riveted
JDG's Avatar
2018 33' Classic
Thanks. Really looks nice like it was OEM.
Old 04-05-2020, 06:39 AM   #10
Rogers , Arkansas
Using Your Resources
Knowing your limits are keys to your own success! It looks fantastic and I know if I did it myself, it would look like I used a hatchet for finish work.
Old 04-05-2020, 12:32 PM   #11
Is there any chance I could get more detailed pics or even drawings? I could then have a cabinet maker in our area do something similar for our Classic 30. Any additional help you can provide would be most appreciated. TIA
Hoagie '59
Hoagette '57
Old 04-06-2020, 09:47 AM   #12
2018 33' Classic
Livingston , Texas
Very well done!
I installed an elfa/Container Store wire basket system in my Classic 33 wardrobe, and it easily quadrupled available storage space.
Aircats is offline   Reply With Quote
Old 06-15-2020, 02:15 AM   #13
2018 30' Classic
Lake Charles , SW Louisiana
[QUOTE=LilPeanut;2347503]Almost done with converting our wardrobe into pantry drawers and converting the pantry from pull out to shelves. Much better space utilization. Also coating all overhead panels with lacquer. Harder and less prone to scratching, water borne.
Can you explain how you secured the shelves you installed ahead of the sofa arms at both the doorside and in between the curbside arm of the sofa and back of dining booth seat back? Maybe some photos of the undersides of these would help. Nice work, been thinking of doing something similar but don't want to do so at the cost of permanent modification to the wall skins.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Old 06-17-2020, 06:55 AM   #14
2020 30' Classic
Albuquerque , New Mexico
Did you consider reinforcing the floor of you closet because of the additional weight? If so how was that done?
Shinytow is offline   Reply With Quote
Old 06-18-2020, 10:18 AM   #15
2019 30' Classic
2 answers. I was worried about the shelf brackets deforming the interior skin. I added 3/16 in thick aluminum riveted to the ribs and then used rivnuts to screw the shelf brackets to the 2 layers of aluminum. It doesnít deform and can hold a computer and 2 cats easily. That also allowed me to place the brackets where I wanted rather than only at ribs. Under Windows there arenít any vertical support ribs.
As for reinforcing the floor of the closet, the weight is carried by a vertical member that the drawers hang from. We made sure the vertical member was supported underneath and we ran a horizontal member in the back along the rear of the drawer section to distribute the load (like the front casing does). We use tension rods to keep the drawers closed in travel.
Feel free to PM and I can give a video tour and answer any other questions. We have traveled a few times with it already and it made a big difference in how organized we feel. Maybe not is how organized we are, but we feel better.
Box sticking out into wardrobe pwlldvd Tommy Bahama Special Editions 23 09-05-2019 11:59 PM
Sliding pantry slider replacement help? (The narrow, wire rack style pantry) brad1 Cabinets, Counter Tops & Furnishings 1 08-09-2019 03:55 PM
2012 Interstate Dual Wardrobe, 2nd wardrobe removable? WillieJ Sprinter and B-van Forum 1 09-07-2016 09:14 AM
Convert 1975 safari Gaucho into queen?? jennylea3382 General Interior Topics 2 03-26-2013 08:05 PM
How Do I Convert A Booth Into A Bed?? evelitalian General Interior Topics 8 07-29-2007 08:46 AM
