Old 05-25-2023, 01:19 PM   #1
2022 30' Classic
New Tazewell , TN
Concerns fixing to purchase 22 classic 30ft twin
Hi thank you for the add. We are looking at 22 30 ft Classic. The deal seems good compared to what we have been researching about 2 yrs. My concern is all the issues with the Czone system and Alde. I know it is a lot of money and I tend to research my way out of a joyful purchase. We have wanted an Airstream for years. I am disabled and the unit being close to the ground is very beneficial for me. I am also very short which limits the comfort of most furniture. I also have to sleep elevated and this unit meets all of my physical needs. Shower seat everything. My main concern is the Czone since it is essentially the motherboard of this unit. I know many of you have been members here for many years and read these posts regularly. Probably most of you could be professors in all aspects of Airstream. Thank you for any help or assurance.
Tcooper24 is offline   Reply With Quote
Old 05-25-2023, 04:05 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Technology can always be a hindering factor for people. So much relies on it and if the main board fails then you’re dead in the water. We full time in our classic for the past 5 years and haven’t experienced a catastrophic failure — well except the heating system but it didn’t stop our journey.
As long as you’re able to just keep rolling, I say go for it. Otherwise if the tech worries you, there are always the other models of airstreams with less tech involved.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is online now   Reply With Quote
Old 05-25-2023, 04:14 PM   #3
InvertdEagle's Avatar
2023 33' Classic
Manassas , Virginia
I think your concerns with CZone and Alde systems are a little overblown. We have a Classic 33 with both systems and our experience has met expectations. In terms of product solutions designed as the ‘brains’ of a smart, connected system, CZone is amongst the market leaders. It’s a pretty good system all things considered. It originally was designed for marine use - high-end yachts and such - and migrated into the RV market. It actually is a collection of components that all work together. Even the switches and buttons in your Airstream are CZone components. The RV market today is demanding “smart” coaches. CZone is at the top of the heap in terms of supporting technologies for these smart RVs. If you’re in the market for a ‘smart RV’ - like any of the newer Airstreams, one equipped with a CZone system is a good choice.
However, since the CZone system is a vast collection of parts (they’re all over your Airstream), there are bound to be more problems statistically speaking than an older, analog RV with no ‘smart technology’ built in. There is just more “stuff” to break. It’s good stuff…but every high-tech gizmo is susceptible to breaking. If you understand the technology, it’s not a big deal. The problem is…few Airstream dealers **really** understand how the whole smear works. And this is why there is a lot of noise on the forums about the problems folks have. The CZone installation in our Airstreams is very much like a computer network and if you understand that, then working with the system is a little easier to think about.
Similarly, the Alde system is pretty good. Requires some understanding of how it works. It’s sensitive to Airstream water pressure…the goal here is to limit the pressures to reasonable values. I keep our coach pressure at 40 psi. We’ve had no issues with our Alde 3020. Importantly, the Alde air cushion needs to be maintained religiously. Some folks never do…and they eventually have issues (the Alde Flow tank usually develops a leak). The issue is that water is incompressible and when the water pressures in your Airstream are too high combined with the water hammer effect when you initially turn on/off the water, the lightweight Alde Flow tank can spring a leak. Maintain reasonable water pressures and maintain your air cushion and you’ll be fine. We really like our Alde system. Quiet, even heat…endless hot water…runs on gas or electric. We’ve got no issues. The biggest issues I’ve seen are with folks kind of ignoring the owners manual with respect to water pressure and maintenance of the air cushion. Again…it’s a really nice system, but requires a wee bit of knowledge from their owners.
InvertdEagle is offline   Reply With Quote
Old 05-25-2023, 11:07 PM   #4
2022 30' Classic
New Tazewell , TN
Many thanks
After reading your explanation I am very appreciative. Your understanding and explanation of these systems has helped greatly. We are waiting for them to have the unit ready and I am excited for the new adventures to come. Thanks again.
Old 05-26-2023, 09:38 AM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Congratulations on choosing the Classic. We bought ours new in 2019 and have loved it ever since. Just remember to relieve the pressure on the Alde system (no matter what your dealer tells you!) and enjoy your Classic for a long long time!
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 05-26-2023, 12:22 PM   #6
2020 30' Classic
2015 25' Flying Cloud
Blue Ridge , Georgia
2020 30' Classic for last 3 1/2 yrs with no problems with the CZone or the Alde system. There is a learning curve and there is a Facebook page for Air Stream Classics which you can post questions and get pretty quick replies. Good Luck and have fun!
Gleverett is offline   Reply With Quote
Old 05-29-2023, 05:49 AM   #7
2022 30' Classic
New Tazewell , TN
Thank you for the Facebook page!
Old 05-29-2023, 05:52 AM   #8
2022 30' Classic
New Tazewell , TN
Thank you 😊 I do have a question if not in use what do you recommend on the pressure release.
Old 05-29-2023, 06:01 AM   #9
"Cloudsplitter"
Thumbs up Welcome aboard...
Don't let all the things that might happen, stop you from enjoying all the things that will.
"You don't know where you've been until you leave, enjoy life" RLC
New purchase concerns tomhamrick Sprinter and B-van Forum 48 05-15-2021 07:31 AM
On Order, 30ft Flying Cloud w/ twin Beds dmotwell Member Introductions 6 10-14-2013 05:56 AM
30ft Classic Twin Bed compartment door Help! wantostream Exterior Storage Compartments & Access Doors 0 05-13-2009 08:37 AM
