Old 03-04-2018, 10:29 AM   #41
2018 30' Classic
2018 33' Classic
Weatherford , Texas
The Audio Visual Supplier will be coming to Texas in a couple of weeks to see my unit and to fully understand the issues associated with the Classic 33 Projector TV. I am on a 3 week trip that will cover 5 camp grounds. I am gathering data for them. I will keep this blog updated.
If you have a Classic 33 please call Airstream Customer Service 877–596–6111 x 7401, ask to speak to Jeremy Allen. They need to hear from you.
smmckean is offline   Reply With Quote
Old 03-04-2018, 08:13 PM   #42
VSM
Vickitn's Avatar
2018 33' Classic
Knoxville , Tennessee
We purchased a 33 Classic a couple of weeks ago. As you suggested I contacted Jeremy Allen about this issue.
On a related note, I was talking to a gentleman at the RV resort where we are in Florida. He said he installed an LG 1500 portable projector in his non Airstream unit. If I understand correctly, the tuner is built into the projector unit. He says it functions wonderfully like a smart TV. It works on cable, the internet and over the air. I admit I am very electronically challenged, but I just wanted to share this information in case it was any help to the ones working on this, which we very much appreciate. Aside from this issue, we are thoroughly enjoying the 33 Classic.
Vickitn is offline   Reply With Quote
Old 04-04-2018, 04:57 PM   #43
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Images: 20
Thanks for all of the information on this issue... I will be picking up my 2018 33’ Classic next week and hope to have some resolution. We do have iPads, Apple TV, Amazon Prime, Netflix. Does the projector have an HDMI input? I’m assuming that we need to plug the Apple TV into an HDMI input on the projector to stream from our iPads?
Hibby
Hibby is offline   Reply With Quote
Old 04-05-2018, 06:39 AM   #44
LetsGetLivin's Avatar
2018 33' Classic
Conroe , Texas
Open HDMI on Viewsonic Projector
There is an hdmi port in the front of the projector that you can use, it’s the easiest to access. I messed with Apple TV, and can use it, however I decided to just use an Amazon Firestick with the app called AirPin (AirPlay/DLNA Receiver Pro) to mirror Apple devices on IOS11 to the screen since it fits directly inside and connects via micro usb without having to wrap wires around the outside of the unit and configuring a split for an additional outlet since they are all being used.
Keep in mind there is a little screw you have to take off to open the small plastic cover. I almost broke it but actually decided to just leave it off anyways for easy access to the hdmi port. I had to loosen the projector screws to lower it slightly to be able to access the small screw keeping the cover fastened.
ID:	307885   Click image for larger version
LetsGetLivin is offline   Reply With Quote
Old 04-05-2018, 07:58 AM   #45
2018 30' Classic
2018 33' Classic
Weatherford , Texas
I, too, have been studying the possibility of using the Apple TV to stream from iPad or laptop...My experience has been that it is necessary to use your cellphone as a hot spot (thus creating data charges) and that most campground networks are not strong or reliable enough to support the stream box (Apple TV or Roku, etc.). Remember the campground networks are trying to support usually 50-400 users. Ask the question, are you using or need the DVD/BR player, if not, replace the DVD HDMI with the stream box HDMI.
Old 04-06-2018, 08:01 AM   #46
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There are a number of ways to set up a dedicated WiFi in your trailer to do all sorts of stuff. Since it's dedicated, it can have all sorts of speed *within* the trailer. Streaming things that are already on your computer will work very well.
Streaming shows *in* from the outside world is a problem. Campground systems generally aren't up to the task. Cell phone systems in remote areas also generally aren't up to it either. If you are close enough to civilization, your phone may do pretty well.
Simple answer - if you *must* have movies (or the kids just will not go to sleep ....) bring along a couple of Blu-ray disks or download stuff to the computer.
Old 04-06-2018, 08:28 AM   #47
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Images: 20
Hi
Thanks Bob! We do download movies to iPads for streaming. We also have a Wifi Ranger and WeBoost 4g-x RV. My biggest concern is the setup for “internal” streaming from the iPad to the projector via Apple TV or other solutions.
Hibby
Old 04-07-2018, 05:58 AM   #48
mojoe7009's Avatar
Green Cove Springs , Florida
This might help with your Apple TV set up:
https://appletoolbox.com/2016/11/con...t-wifi-how-to/
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 04-07-2018, 06:05 AM   #49
mojoe7009's Avatar
Here’s a thread that may help as well:
Streaming movies from your iPad to your TV
http://www.airforums.com/forums/showthread.php?t=110679
Old 04-07-2018, 06:35 AM   #50
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Images: 20
Thanks MoJoe!
Very much looking forward to trying this out! I was hoping to pick up today, but we got hit with snow over the last three days and I don’t want to bring it home on roads that are covered with salt/chemicals...
Maybe next weekend can be an inaugural run!
Hibby
Old 04-07-2018, 09:03 AM   #51
Mollysdad's Avatar
I tried to copy movies to my I-pad. But I was never happy with the resolution you ended up with because of the transfer. To get a movie down to about 6 gig in MP4, it loses a lot of picture quality. I'd rather just carry a handful of DVD's.
Old 04-25-2018, 12:29 PM   #52
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
Hey smmckean, ....
Haven't seen any recent updates.
Has AS given you any feedback as to a solution?
davcarv is offline   Reply With Quote
Old 04-26-2018, 08:14 AM   #53
2018 30' Classic
2018 33' Classic
Weatherford , Texas
We have had a successful test using another projector which has the Smart TV tuner which does work similar to the Samsung TV in the BR for both OTA (antenna) and Cable reception. AS AV person was with me in my unit as we tested and recorded the necessary data which has been shared back at the factory and the decision makers as they are planning for the 2019s as well as developing a plan to fix the 2018s. I am told that the wheels of progress move slow similar to construction of the Great Pyramids. I am trying to keep grease under the stones as they are inched forward.
Old 04-26-2018, 08:19 AM   #54
VSM
Vickitn's Avatar
2018 33' Classic
Well this is positive news. Thank you for the update.
Old 05-03-2018, 06:28 PM   #55
DeltaRon's Avatar
2015 28' Flying Cloud
2018 33' Classic
Cumming , Georgia
I just bought the 2018 Classic 33. When we close on 5/17, if this problem is true, then I will kill the deal.
DeltaRon is offline   Reply With Quote
Old 05-05-2018, 06:51 AM   #56
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
I had a conversation with AS,...(the guy in an earlier post in this thread). It was a very reasonable conversation and there is an issues still. They’re looking at options but it’s still ongoing. As with most things in life the devil is in the details. Can they find a projector it’s in the existing cabinet if they can’t they do it a existing cabinets. What are they do with all the existing do they issue a recall etc. etc. etc.
I wish there was an easy button.
Old 05-05-2018, 08:45 AM   #57
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Just glad I found out about this issue before I took delivery. Now I can pull out of the deal.
Old 05-05-2018, 10:16 AM   #58
2018 30' Classic
2018 33' Classic
Weatherford , Texas
As I have previously stated, I have identified an issue that Airstream had not experienced previously or that was unaware. I have worked with them to correct this with the best possible outcome for all of us Classic 33 owners. We have identified a replacement projector and conducted successful tests with their AV person, Airstream has reviewed the data (I have been to 6 different campgrounds and several different sites within those campgrounds - and I have provided data from each) and they appear to be developing a plan to correct this, processes take time to ensure their dealers are able to understand and address the replacement satisfactorily per Airstream requirements. In the mean time, I am watching my satellite TV. (Directv with portable satellite dish)
Old 05-08-2018, 03:49 AM   #59
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Images: 20
Thank you! I look forward to the results... I’m wondering if the new projector has more than one HDMI input, and preferable one on the front of the projector? It would make it so simple to plug in an additional source (i.e. Apple TV) to enhance my viewing pleasure!
Hibby
Old 05-09-2018, 06:11 AM   #60
2018 33' Classic
Conroe , Texas
Awesome, thanks for taking the time to work through this and keeping us all updated.
Classic or Classic Limited? Bluto 2006 - 2010 Classic (all lengths) 8 03-23-2009 09:10 PM
- Classic FB 27' or Classic 30' Sky Community Polls 2 05-11-2007 02:34 PM
Classic Weight Example - 2004 Classic gklott 2001 - 2005 Classic 6 11-05-2005 12:02 PM
Classic 25A / Classic 25B DreamStream 2001 - 2005 Classic 8 04-27-2004 05:19 PM
Classic models - 2002 Classic baldeagle 2001 - 2005 Classic 48 04-16-2004 10:31 PM
