Old 09-28-2017, 04:35 PM   #1
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
Check your waterless traps
Our 2017 Classic has what they call water-less traps in place of common P-traps. I had never seen this type of water-less traps before. They appear to be nice vs. old style P-traps. When replacing our flat bottom bathroom sink i had to re-work the under sink plumbing. When I took the trap out I notice the flexible sealant used at mechanical joints by the factory was approximately 3 times more than required. Looking into the trap there was a lot of sealant in the 90's and through out the trap it's self. The amount of sealant inside was enough to restrict and more than likely cause a plugged drain system. Cleaned it out, should have taken pictures, however I did not. Seeing what had been in the bathroom sink drain, I thought best to look at the drain line under the kitchen sink. The flexible sealant used appeared ok, however the amount of glue used to put the ABS together was a lot, way more than should have been used. Cleaning the excessive glue out is difficult to say the least. Again the amount of glue I found inside the ABS most likely would have caused drainage problems down the road. I did take pictures and have attached. My opinion to others is check your drains lines. If yours are free from obstruction good, if not clean them out. When putting mechanical fittings back together, suggest using a non hardening TFE pipe sealant. sbowman
ID:	295760   Click image for larger version
sbowman is offline   Reply With Quote
Old 09-28-2017, 04:46 PM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
So no need anti freeze in traps if I blow lines out? Really waterless?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-28-2017, 09:20 PM   #3
1979 23' Safari
Wayland , New York
Supposedly. They still hold a little water above the seal, especially when horizontal. So I'm cautious and add a little antifreeze.
Old 09-29-2017, 01:54 AM   #4
Long Island , New York
Water-less traps -- another Airstream "improvement" . . .
For winterizing I would add antifreeze to these -- definitely.
Peter
Old 09-29-2017, 10:42 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If the trap is waterless, what exactly is the trap trapping?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-29-2017, 10:45 AM   #6
sbowman's Avatar
smell sewer gases
sewer gases, smell. sbowman
Old 09-29-2017, 10:48 AM   #7
m.hony's Avatar
2013 30' Classic
I guess how a P-trap works is by using a little water to block smells/sewer gases?
So how does the waterless trap work? One way flapper/valve?
Please pardon my ignorance/curiosity.
TAC #MS-10
Airforums #70955
Old 09-29-2017, 11:23 AM   #8
2007 22' International CCD
Yup. It's two teflon flexible flaps that close agains each other to seal against backflow. They spread open to let water and minor particles through. They are soft, so it's not a good idea to run a snake down them...
Old 09-29-2017, 02:43 PM   #9
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
http://hepvo.com/
Old 09-29-2017, 03:41 PM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Dropping a little antifreeze down the drain is a good idea no matter what sort of trap. There are all sorts of odd places for water to pile up .... Once you are on the drain side, there isn't much trouble doing it.
Old 09-30-2017, 05:01 AM   #11
Warning of incessant echo!
The new search function here -- powered by Google to search only this forum -- in the blue box above -- works great!
"waterless trap" search results:
https://www.google.com/search?q=wate...=airforums.com
Fresh Cab, Peppermint Oil and Traps? badkat Full-Timing 8 08-03-2015 10:41 AM
Waterless P Traps ? alumascoupe Plumbing - Systems & Fixtures 11 09-05-2014 08:17 PM
HEPvO waterless valve hampstead38 Sinks, Showers & Toilets 3 09-12-2010 07:23 PM
Speed Traps Janet H On The Road... 48 12-12-2007 06:12 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
