Old 08-16-2020, 11:52 AM   #1
2019 30' Classic
San Jose , California
Cabinat Door Latches
2019 Classic 30': Does anyone know if the door latches (see pictures from sink cabinet) on some of the cabinet doors are available to order separately? I would like to install them on the overhead lockers as added security against them opening if something shifts while on the road.
Thanks!
2019 Classic 30 RBQ
2020 RAM 3500
ProPride
ID:	376015   Click image for larger version
ronalddodge is offline   Reply With Quote
Old 08-16-2020, 11:54 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes they are available at most RV stores. I bought some on Amazon.
2019 Ford Expedition Platinum
Old 08-16-2020, 12:04 PM   #3
Mollysdad's Avatar
Yes, I bought the exact one's on Amazon.
They're available in three strengths 3#, 5# and 10#.
Allegedly the spring is color coded, but I'll be darned if I could tell.
I changed the stock latch to a 10#. Pretty stout.
You want the one's made by Southco for a perfect match
https://www.amazon.com/Southco-Passi...ap_d_rp_1_41_t
Old 08-16-2020, 12:25 PM   #4
2019 30' Classic
thanks All... just ordered 12! My cabinets are only opening when desired!
Old 08-16-2020, 12:57 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
If you weren't so quick on the draw I'd have suggested these as a much improved solution to the plastic latches Airstream mounted from a low cost, high fail supplier:
https://www.amazon.com/Ekatoo-Adjust.../dp/B07PVN1JMQ
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-16-2020, 03:57 PM   #6
2019 30' Classic
Very Nice! Added to the parts inventory of like-kind models if the replacement ones don't work out.
Ron
Old 08-16-2020, 04:41 PM   #7
Mollysdad's Avatar
Yes, those are nice. I chose to stay with the Southco but upped the strength because all the screws lined up. And you can't see the latch when closed.
But if I were starting from a clean surface, I'd use yours.
Rock Guard and Door Sprung Latches cameront120 Rock Guards, Segment & Window Protectors 6 03-16-2006 09:16 AM
1970s Closet Door Latches mello mike Cabinets, Counter Tops & Furnishings 2 11-11-2004 11:40 AM
Cabinet/door latches manley Commercial Listings 1 11-01-2004 02:39 PM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
Cabinet door latches 53flyingcloud Cabinets, Counter Tops & Furnishings 3 07-08-2002 03:28 PM
