Old 03-31-2019, 12:35 PM   #1
2019 33' Classic
Scottsdale , Arizona
Blind Malfunction
When putting the big blind by the dinette (33 classic 2019) down only the right side goes down. So the blind gets all skewed trying to lower. This is a brand new trailer, just out on our first trip. It had worked before. Any ideas?
trepine is offline   Reply With Quote
Old 03-31-2019, 11:06 PM   #2
2015 25' Flying Cloud
2018 33' Classic
​2020 Atlas​
Pullman , Washington
We had to have the blind fixed at the dealer for out 2018 33. It works great now.
WA_Airstream is offline   Reply With Quote
Old 04-01-2019, 04:56 AM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
We had a problem with one of our blinds in our Signature. Since it had failed I tried to take it apart to fix. That was a mistake. These things are very complicated and just the process of taking it apart is enough to guarantee it will not go back together again! I'm pretty handy with things but this thing scared me.
Let your dealer replace it. Just make sure the die lot looks correct. When they replaced mine, they replaced both windows near each other to keep the color the same. Of course, this was Jackson Center.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 04-01-2019, 07:09 AM   #4
Mike0392's Avatar
2019 33' Classic
Estes Park , Colorado
Mine would not go down all of the way. Jon from Airstream called and walked me through. I disconnected the lower rail popping the lower clips using a screwdriver. Holding the lower rail down as far as I could reach and level. Using the phone app. I cycled the blinds several times, all the while holding the lower rail level and as low as possible. This reset the automatic stops. No trouble since Jpuckett@airstream.com is the man with the plan.
Mike0392 is offline   Reply With Quote
Old 04-01-2019, 07:10 AM   #5
Mike0392's Avatar
2019 33' Classic
I can give you tips on troubles and fixes as I have a 2019 Classic 33 also
Old 04-01-2019, 09:49 AM   #6
2019 33' Classic
Thanks for the replies. At least itís a minor annoyance, iíll reach out to AS, thanks for the contact info.
The only other, but major gremlin we have now is the hot water. When we turn on the faucet it will warm up to hey very warm temperature, but only stays at that temperature for about five seconds, and then cools off to lukewarm. I have been reading the alde thread, but there is so much information in there itís hard to sort out .
So far iíve replaced the air cushion, checked the glycol lever, and adjusted the mixing valve as per instruction. but nothing seems to change much.
The heater function is working superb.
In the service menu it shows water temp around 150 degrees.
Itís frustrating thatís itís this fickle.
Old 04-02-2019, 05:10 AM   #7
Mike0392's Avatar
2019 33' Classic
Google Alde mixing valve technical bulletin and follow the instructions step by step.. valve is located under the dinette seat closest to the door. Use gas and power for the boost
Old 04-02-2019, 06:55 AM   #8
2019 33' Classic
Thanks for the tip. I havenít tried purging air from the bleed valves yet, i donít have any alde fluid at the moment so i didnít want to do that until i did. iím assuming that this would not have any affect on the water heater specifically though as it seems like it would be related to the overall radiator heat function. And also, the heater seems to be working fine.
Hopefully the mixing valve thing will work.
Old 04-02-2019, 10:01 AM   #9
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi trepine,
Congrats on your new Airstream! We're very sorry to learn about the issues you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Burner malfunction 78SovIntl31 Stoves, Ovens & Microwaves 2 01-26-2014 05:03 AM
RF causing brake controller malfunction nm1oqrz Phone, CB & Ham Radio 6 04-12-2011 06:03 PM
GM truck antilock brake malfunction dwightdi Tow Vehicles 20 03-13-2006 04:38 PM
345 LP Tank Gauge Malfunction cooperhawk LP Gas, Piping, Tanks & Regulators 1 12-06-2005 01:36 PM
water heater malfunction--help! ready to depart for xmas trip! susanborck Water Heaters, Filters & Pumps 23 12-22-2003 10:31 PM
