Old 10-08-2017, 07:54 AM   #1
Anywhere , Alabama
Black Tank Flush Pressure
Hi folks. I appreciate all the feedback on use of water regulators on fresh water line. Now, it doesn't appear that the black flush system has a pressure regulator built in as the fresh does. So, do most of you use a regulator at the spigot for flushing the black tank? Just trying to make sure I don't burst something.
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 10-08-2017, 08:42 AM   #2
2018 30' Classic
New York , New York
We took ours off because at our campground the water pressure at the spigot that drawing it from the fresh water tank with the pump is better.
ajwbarnard is offline   Reply With Quote
Old 10-08-2017, 10:28 AM   #3
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
You would think I'd have thought about this, but never have. I simply hook up one of the self collapsing hoses directly and run it full for about two minutes, shut the water off and let it flow. I do this as often as possible while traveling if I have time but really do it when we are putting the trailer away for the winter, or until we head south.
But, now you have me thinking, just a bit.
Bud
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
Old 10-08-2017, 10:36 AM   #4
Reads a lot
Titusville , Florida
I do use a regulator at the spigot, always have. Most of the time it isn’t really needed but I have been to a couple of place where the water pressure seemed too HIGH. Some places the water pressure is too low but I still use the regulator just the same. It is part of my arrival and departure check list. So far it worked great for me.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 10-08-2017, 10:53 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
There is no need to regulate pressure on the back tank flush (unless it becomes plugged). Inside the black tank there is open end spray nozzle that lets the water go through with very little pressure buildup on the supply pipe. The pressurized spray and free water flow is what cleans the debris out of the tank.
I think in the case of the back tank flush, more water pressure/flow is better.
Alan
Old 10-08-2017, 11:54 AM   #6
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I blew the top off the cheap backflow preventer airstream installed with too much pressure.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 10-08-2017, 12:31 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I agree, those cheap plastic valves are junk, and they fail occasionally.
Is it possible the plastic valve had a little water left inside, that froze over the winter?
I've used unregulated water pressure on my several different Airstreams, for more than 25 years. I've had no damage,,, yet.
Alan
Old 10-08-2017, 12:41 PM   #8
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Don't think so. It was when my trailer was new and the campsite did have really high pressure.
I've removed the valve and just inserted an elbow in its place.
Old 10-08-2017, 01:54 PM   #9
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Where was/is that valve on a17 classic?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 10-08-2017, 04:39 PM   #10
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Not sure. Mine is a '14 bunk. It was behind a closet right above the inlet. I suspect yours is above the inlet as well.
Old 10-08-2017, 05:03 PM   #11
2014 30' Flying Cloud
Ponce Inlet , Florida
Access on my 14 30' FC is under the bathroom sink it's on the outboard wall near the black water flush inlet. It's easy to see not so easy to work on. Mine failed and was replaced under warranty. As other have said it's made of clear plastic. If it fails now I would replace with an elbow as well.
Beach Bum is offline   Reply With Quote
Old 10-08-2017, 05:47 PM   #12
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Mine was a real pain to get to. That's one reason I went to an elbow. Didn't want to deal with it again.
Old 10-08-2017, 06:17 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I tend not to use full open pressure with the black tank flush. They are notorious for blowing out, and ours is nearly impossible to get to without removing the vanity, so I'd rather take it easy and rely on the volume of water in the black tank to carry everything out rather than high pressure spraying action. I run it until the black tank is about 3/4 full and cut it loose ... then repeat until it runs clear. (We don't usually do the "full" flush while on the road, between campgrounds until it's time to go home.)
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair & PastPrez, 4CU/WBCCI
#3954
Old 10-09-2017, 11:08 AM   #14
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Never thought about it.
I guess you want high pressure to blast the black tank.
Not sure the black tank flush system can be damaged by high pressure since it is basically designed for some pressure and the water has an outlet- the nozzles in the tank.
It's amazing that some folks think to ask things that never crossed my mind...
No trouble with pressure in the black tank flush system so far 7 years in.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-09-2017, 12:21 PM   #15
2012 23' FB Flying Cloud
Woodstock , Ontario
The black water tank has an external vent on the roof and thus you cannot pressurize the tank so no need to worry about too much pressure. Descent pressure and volume are needed to clean the tank.
terrythomts is offline   Reply With Quote
Old 10-09-2017, 03:16 PM   #16
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
At the last CG that I was at, the water pressure was 80 PSI.
I use a Valtera pressure reg for supply to the trailer; but for the tank flush, I just use direct pressure. It worked great. No problems yet.
But looking inside that area under the bathroom sink, I do not see a "plastic" valve assy.
Looks like brass.
Am I looking at the right thing? (On a 2016 30' FC, that's listing For Sale.)
MelGoddard is offline   Reply With Quote
Old 10-09-2017, 09:49 PM   #17
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I plugged up a no-fuss-flush valve by letting the black tank fill too full and sitting a while. I could not get city water pressure to un-block it. While at Jackson Center a service tech un-blocked it in the shop. He said the city water pressure was a lot higher in Jackson Center than most. It has been OK since with no leaks or damage. Next time I will use compressed air till it blows clean.
guskmg
Old 10-10-2017, 05:09 AM   #18
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I hope it's a hose dedicated to this and not also used for your city water connection.
2019 Ford Expedition Platinum
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Black Water Tank Flush: Park Water Pressure cbrittan Waste Systems, Tanks & Totes 2 08-01-2016 05:32 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
black tank flush - pressure regulator? bradk Waste Systems, Tanks & Totes 12 04-30-2006 06:08 AM
